Need way to protect interior of garage doors. - Router Forums
 11Likes
post #1 of 23 (permalink) Old 01-10-2019, 07:59 AM Thread Starter
sgcz75b's Avatar
First Name: Steve
Default Need way to protect interior of garage doors.
I just installed new garage doors and am looking for a way to protect them from sawdust, grinder debris, and other workshop materials. As I put many of my cutting tools near the door to be able to raise the garage doors and blow out the left-over detritus, it didn't matter so much with my old wooden garage doors. But now with my insulated doors, I want to protect them.
I can attach cardboard/heavy craft paper, or drop-cloths to the door while it's closed, but I would like something that can ride with the doors as they open without dropping down into the work area.
Any suggestions would be appreciated.
So happy to have found this forum and have found the information so useful. Thanks.
sgcz75b is offline
post #2 of 23 (permalink) Old 01-10-2019, 08:07 AM
difalkner's Avatar
First Name: David
Welcome to the forum, Steve!
What sort of dust collection do you have in place? I collect most of the dust from the source with shop vac and dust collector and I have a filtered fan recirculating air in the shop, so there's very little airborne dust to get on the garage door. For the grinder I'd put a deflector at the exhaust port to keep that from spreading around the room.
Got any photos of your set up?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 23 (permalink) Old 01-10-2019, 11:19 AM Thread Starter
sgcz75b's Avatar
First Name: Steve
I have a shop-vac system using the Home Depot Dustopper that works surprisingly well. Easy to hook-up to each tool or situation, but some sawdust and crap always manages to avoid the vacuum. At the end of the day I take my leaf-blower, raise the doors and blow out the garage from back to front which is not a problem. I just want to keep my garage doors white and as spotless as possible. Thanks.
No photos as I'm re-arranging tool placement as I'm looking to add a router table, table saw, and band saw soon as I make-up my mind as what to get.
Thanks.
difalkner likes this.
sgcz75b is offline
post #4 of 23 (permalink) Old 01-10-2019, 12:32 PM
Assuming it's a roll up type door. Get some thin white board in sheets. Cut them into segments to fit the door. These will protect the door, but this will add weight so you'll have to reset the spring tension--I hired that done, those springs can break an arm in a flash. You can also get some foam insulation sheets to put under the white board. I put some aluminized bubble sheets of radiant barrier behind the insulation to cut down on heat transfer through the door (heat coming in during summer, out in winter). Repair damaged spots with white gaffer's tape.
post #5 of 23 (permalink) Old 01-10-2019, 04:07 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
Solved (for now). While moving things about I found this plastic tarp. Attached with zip ties, old rope, and with a healthy dose of duct tape. Had to move the garage door sensors out a few inches but it should do the trick for a while. The door is already insulated to R12 and good weather-stripping sealing on the exterior. My old door was wooden and had no insulation. Today, even in the low 20s outside the garage was a balmy 64 with no heat. Since it's partially covered by dirt and heated building on three sides, it should remain pleasant winter and summer.
And thanks for your "17 things" article. A great read and I immediately ordered the Bill Hylton book. I've placed your pdf on my computer desktop for quick reference.
Thanks again.
Steve
DesertRatTom likes this.
sgcz75b is offline
post #6 of 23 (permalink) Old 01-10-2019, 04:31 PM
Hello Steve and welcome to the forums...
how about poly-coated paper sheets...
seeing you are the new guy... We have some reading for ya at this link that just may be of some help/use to you...
post #7 of 23 (permalink) Old 01-10-2019, 08:13 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
Thanks! I love to read and study about all my interests. I appreciate it!
Steve
sgcz75b is offline
post #8 of 23 (permalink) Old 01-10-2019, 11:33 PM
old55's Avatar
First Name: Ross
Welcome to the forum Steve.
Ross,
old55 is online now
post #9 of 23 (permalink) Old 01-11-2019, 12:02 AM
To avoid the sag, consider using double sided carpet tape on the steel door. It should greatly reduce the sag, and it will look fairly good as well. Thanks for the comment on the 17 things article. I update it from time to time, particularly after adding a new tool, or learning a new lesson.
post #10 of 23 (permalink) Old 01-11-2019, 08:38 AM Thread Starter
sgcz75b's Avatar
First Name: Steve
Good idea about the carpet tape. This was a quickie fix, though I've noticed that sometimes quickie fixes become decades-long fixes!
sgcz75b is offline
Garage doors mailee Show N' Tell 8 01-09-2013 05:49 PM
garage doors - overhead glenndee New Member Introductions 6 09-28-2009 10:46 AM
Garage doors mailee Show N' Tell 5 06-05-2007 10:27 PM
