Un Nailed - Router Forums
 8Likes
  • 2 Post By DaninVan
  • 1 Post By Stick486
  • 3 Post By mimac
post #1 of 9 (permalink) Old 01-11-2019, 03:01 PM Thread Starter
Default Un Nailed
Atelier du Bricoleur (menuiserie)…..…… Woodworking Hobbyist's Workshop <[email protected]> had a new post up featuring this little beauty...
https://atelierdubricoleur.wordpress...s-pneumatique/
Danman1957 and Roy Drake like this.
DaninVan is offline
post #2 of 9 (permalink) Old 01-11-2019, 03:36 PM
common headed and ring/spiral shanks are a different story..
and how can you legitimately work free into this???
Danman1957 likes this.
post #3 of 9 (permalink) Old 01-11-2019, 05:08 PM Thread Starter
Well, the wood is free; it's the nails that cost.
DaninVan is offline
post #4 of 9 (permalink) Old 01-11-2019, 05:15 PM
was the wood delivered free of charge???
or did you not take into consideration the time and vehicle expense to get those pallets home..
people that yell free don't/can't/want to think things through...
post #5 of 9 (permalink) Old 01-11-2019, 05:17 PM
side note...
the guy in the video could have pounded those nails back trough a little safer..
post #6 of 9 (permalink) Old 01-11-2019, 05:19 PM Thread Starter
I don't use pallet wood so not my problem.
Barry747 and Herb Stoops like this.
DaninVan is offline
post #7 of 9 (permalink) Old 01-11-2019, 05:20 PM
mine either...
post #8 of 9 (permalink) Old 01-11-2019, 06:17 PM
JOAT's Avatar
First Name: Theo
The pallets I have worked with, when you pull the slats off, normally the nails pull thru the slats, and are left sticking out of the 2X4 cross members. With that gizmo, the nails would only be driven into, not thru, the 2X4s. So it would not work well on pallets at all.
Those nails are brittle, and if you try to pull them out, you can pull very few, they usually break. You can get them out tho, with a hollow drill bit in a drill. You'll make a bit of a hole, but those can be patched/plugged, and you won't have a nail left in the wood. A bit time consuming, but all in all usually worthwhile.
JOAT is online now
post #9 of 9 (permalink) Old 01-11-2019, 07:56 PM
mimac's Avatar
First Name: Brian
What you don't make coffee tables.
kp91, Barry747 and DaninVan like this.
mimac is offline
Wood moisture content, higher in my new shop Duane Bledsoe Tools and Woodworking 19 09-28-2015 03:10 AM
Garage Overall for Shop TRN_Diesel Workshop Showroom 558 10-24-2010 02:44 PM
I bit of extra shop storage tdsapp Show N' Tell 16 12-03-2009 11:36 AM
