Jigsaw Recommendation - Router Forums
 38Likes
post #1 of 41 (permalink) Old 01-13-2019, 07:46 PM Thread Starter
peterbata's Avatar
First Name: Peter
Default Jigsaw Recommendation
Hello all.
I am looking to purchase a used jigsaw and am willing to spend up to a maximum of $100.00 if possible. I will be using it on 3/4" MDF. If that helps any.
Would you be so kind as to give me some recommendations. Thank you. Peter
It's better to burn out than to fade away!
peterbata is offline
post #2 of 41 (permalink) Old 01-13-2019, 08:17 PM
kp91's Avatar
First Name: Doug
Under $100 is going to get you a lighter duty saw. I have the old corded Grizzly, and it is a beast, but I don't think they sell that one anymore. Dewalt sells one that looks a lot like it
Try a couple and see which feel good in the hand. Hitachi, Dewalt, some of the craftsmans look solid. The best advice I can give on a cheaper saw is to use good blades. I use Bosch blades, usually the progressor series. They make a underpowered saw cut better.
Refurbished is another option https://www.sears.com/bosch-factory-...5&blockType=G5
Check out the classifieds, if you find a Bosch under $100, go for it
https://annapolis.craigslist.org/tls...793496557.html
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 41 (permalink) Old 01-13-2019, 09:15 PM
JOAT's Avatar
First Name: Theo
Huh, I've got a B&D I got around 1977, probably the least expensive they had. It's been used from 1/4" plywood, up to 2X4s, and still working just fine.
peterbata likes this.
JOAT is online now
post #4 of 41 (permalink) Old 01-13-2019, 10:19 PM
Originally Posted by peterbata View Post
Hello all.
why play around...
move to the head of the class..
https://www.cpooutlets.com/bosch-jig...n&prefv1=recon
TenGees and Herb Stoops like this.
post #5 of 41 (permalink) Old 01-13-2019, 11:21 PM
gdonham1's Avatar
First Name: Guy
I too am looking at buying a new Jig Saw. I currently have about a 10 year old Black and Decker. I absolutely hate the thing. It was made before the newer crop that have orbital patterns and still has the older blade mounting. The newer saws have the bayonet type blades that are easier to change and get right.
I have Dewalt 20V tools and have looked at the 20V Jig saw to cut the cord. I bought the drill first that came with 2 small batteries. I later bought the 6.5" circular saw and a 4" cutoff/grnder tool. The saw and and grinder eat batteries so I bought 2 five amp hour batteries.
So what I have read the Bosch corded is pretty good. They have several models but of course the most expensive one is the best.
So I have a similar problem about deciding what to buy. I do not want a used one for a tool in this price range. Besides finding a used decent tool is like looking for a needle in a hay stack. Usually you do not find the needle but you sure can get stuck by a needle in the haystack.
Should I get a new Bosch corded or go for the Dewalt 20V. The Dewalt is about 160.00 everywhere and the Bosch is about 150.00 to 220.00 (model JS470E and JS572EK respectively) on Amazon.
Please give me any feedback about the Dewalt 20V Jigsaw and/or the Bosch saws.
gdonham1 is offline
post #6 of 41 (permalink) Old 01-14-2019, 12:30 AM
visit the link I posted...
post #7 of 41 (permalink) Old 01-14-2019, 04:08 AM
etaf's Avatar
First Name: Wayne
i have had a few Jigsaws , old B&D from the 70's and a borsch , I do like the Borsh.
However, I recently started investing in cordless Dewalt (circular saw, planner , drill etc ) and purchased the cordless Jigsaw - NOT the brushless version
its great , not having to worry about the cable and works very well with both 2AH and 3AH Batteries
Although I'm only a DIYer so the usage is not high
I recently made up a Window seat using 18mm MDF and it worked well and the batteries on the Circular saw, Jigsaw, Drill and Impact driver , easily lasted the couple of days, without recharge, to construct and install
Although the blower set to blow across the sw, did not seem to clear the dust easily
Wayne
etaf is offline
post #8 of 41 (permalink) Old 01-14-2019, 08:40 AM Thread Starter
peterbata's Avatar
First Name: Peter
why play around...
Thank you @Stick486 . I would have jumped on a Bosch refurb. Had I not lived in Canada! Deja Vu right!
Danman1957 likes this.
post #9 of 41 (permalink) Old 01-14-2019, 08:42 AM Thread Starter
peterbata's Avatar
First Name: Peter
Thank you all for the great suggestions. One thing that I have working against me is that some of the suppliers that have been mentioned do NOT sell / ship to Canada. One more question Barrel-Grip vs Top-Handle
post #10 of 41 (permalink) Old 01-14-2019, 08:45 AM Thread Starter
peterbata's Avatar
First Name: Peter
@kp91 Thank you. I came across a used Bosch 1587AVS that comes with several blades for $100.00. Your thoughts? Actually, I just came across the Bosch JS260 120-Volt Top-Handle Jigsaw from Home Depot for $82.00. I wonder if it is that an Uber entry level unit though
best jigsaw tables laurencewithau Tools and Woodworking 6 05-23-2017 07:45 AM
Barrel Grip vs Top Handle Jigsaw analog_gamer Tools and Woodworking 20 02-02-2015 08:40 PM
Mounting Bosch Jigsaw to Router Baseplate - finished Ladd Table-mounted Routing 4 02-06-2008 05:47 PM
