Neat track saw alternative - Router Forums
 28Likes
  • 13 Post By kp91
  • 4 Post By DesertRatTom
  • 1 Post By Nickp
  • 3 Post By JOAT
  • 2 Post By sreilly
  • 2 Post By JOAT
  • 2 Post By TenGees
  • 1 Post By RainMan 2.0
post #1 of 10 (permalink) Old 01-24-2019, 02:54 PM Thread Starter
kp91's Avatar
First Name: Doug
Default Neat track saw alternative
For us cheap guys....
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #2 of 10 (permalink) Old 01-24-2019, 03:14 PM
That is a great solution. Zero clearance too. I think you might want to run the first edge through a jointer to get a truly straight edge on it. Most common wood is going to have some small irregularities you'd want to get rid of. The thickness of a folded sheet of paper is all the wiggle room you have for side to side movement, and a small warp on the straight edge would bind the saw.
I think you'd want one of these to be at least 6 feet long, maybe aeven, depending on the position of the blade and bottom of the saw.
With a battery operated saw, this would be something you might want on a job site, not just in the shop. Drill a hole on one end so you can hang it up for storage. You might also want to lay two long pieces of low friction tape for the saw to slide along smoothly. Given my memory, I'd also print a reminder on it to keep the good face down to reduce tear out. The blade you set it up with shold also be labeled for that use. You wouldn't want a mis-fit that would destroy the zero clearance quality.
One thing about a track saw is the ability to lower the blade safely and accurately into the wood. I suppose you could do that with this jig, but it would really be easy to mess it up as you pushed the blade down, or used the blade depth settings on the saw. The track saw uses a depth stop so you can avoid accidentally cutting too deep. I keep a big sheet of flat foam insulation around for track saw use.
kp91, OPG3, RainMan 2.0 and 1 others like this.
post #3 of 10 (permalink) Old 01-24-2019, 03:23 PM
Nickp's Avatar
First Name: Nick
KISS...can't ask for better...
Thanks for posting...you hit it on the head "for us cheap guys"
OPG3 likes this.
Nick
Nickp is online now
post #4 of 10 (permalink) Old 01-24-2019, 04:42 PM
JOAT's Avatar
First Name: Theo
Definitely, the holes are a great idea.
You may be cheap, but I'm not, I am financially challenged.
kp91, OPG3 and DesertRatTom like this.
JOAT is online now
post #5 of 10 (permalink) Old 01-25-2019, 09:54 AM
sreilly's Avatar
First Name: Steve
This certainly is a cost effective method but I'm wondering how good the cut edge would be. I guess that really depends on the quality and condition of the blade or is this not a concern and just rough sizing to make final cuts on the table saw? BTW, my wife says there's nothing cheap about me when it comes to tools.....
sreilly is offline
post #6 of 10 (permalink) Old 01-25-2019, 02:19 PM
JOAT's Avatar
First Name: Theo
I don't know about everyone else, but I don't need a 100% dead on cut, just close. Right now at least, I want everything I cut just a shade oversize, because it will be used with a master and routed to exact size. This would be easier for me to use, and plenty accurate, over anything I've seen, or come up with. So this design is what I'm going for. Not going the one size fits all route tho, going to make at least two lengths, possibly three. A hole on the end will allow hanging on the wall, out of the way. I love K.I.S.S. And, if you wanted to get fancy, I'll bet you could make versions that would cut angles. Now just waiting to see if Woodpecker will come up with a $300 version.
kp91 and Arcola60 like this.
JOAT is online now
post #7 of 10 (permalink) Old 01-25-2019, 02:41 PM
TenGees's Avatar
First Name: Paul
This is going on my project list.
Considering Tom's concerns: I wonder if something could be made to add a depth-stop to a circular saw. Maybe a screw and wingnut in the curved slotted piece where the depth is adjusted. If a screw could be made to fit the slot to keep it from turning, that would simplify adjusting it. And maybe a spring could be added somewhere to make the saw plunge. hmm...
Sorry, thinking out loud.
kp91 and DesertRatTom like this.
TenGees is online now
post #8 of 10 (permalink) Old 01-25-2019, 07:34 PM
JFPNCM's Avatar
First Name: Jon
Interesting approach. Reminds me of the old trick of adding rails to a long 2x 12 and laying grooved cross pieces (typically the grooved edge of tongue and groove siding with the top edge of the groove shaved off) on it to use for square and 45 degree cutoffs on the job site. A nice stable work surface as well.
Jon
JFPNCM is offline
post #9 of 10 (permalink) Old 01-26-2019, 12:05 AM
RainMan 2.0's Avatar
Wish I seen this video about 25 years ago. Could have saved me some cursing
kp91 likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 10 (permalink) Old 01-26-2019, 09:16 PM
From what I saw, there's no "lowering the blade" into the cut, except maybe on the initial cut where he put the kerf in the jig - the jig overhangs the material, the saw laid in place with the blade not touching the material and the saw then started. As with all these type of jigs, I've always wondered why everybody makes the base out of 3/4" plywood - the one that I used for years was made out of 1/8" tempered Masonite, worked very well and at a fraction of the weight. After several years, I did have to move the fence over and recut the edges though.
tomp913 is offline
Track Saws Steven Owen Tools and Woodworking 174 10-14-2017 12:18 AM
Triton plunge, track saw review DesertRatTom Tool Reviews 11 09-29-2017 10:38 AM
For Sale: Eagle-America Wooden Train & Track Kit Ray Newman Woodworking Classifieds 0 10-04-2015 04:42 PM
Anyone use a Festool track saw ? RainMan 2.0 Tools and Woodworking 39 07-03-2015 04:07 AM
A "closed-in" mitre track? matt1710 Table-mounted Routing 8 05-22-2011 07:27 AM
