Ridgid Spindle/belt sander problem - Router Forums
 5Likes
post #1 of 13 (permalink) Old 02-05-2019, 12:52 AM Thread Starter
Default Ridgid Spindle/belt sander problem
My Ridgid spindle sander started acting up. It seems to take a lot less pressure to bind it up and then it won't restart the sander. I get a buzz, and it might go with a little help, go by itself, or just buzz and do nothing. When that happens there is a burning smell. Any ideas besides the motor being shot? It's a good 2-3 years old and has been a great tool. Just started this tonite.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #2 of 13 (permalink) Old 02-05-2019, 01:11 AM
motor..
does it have brushes...
time to test the lifetime warranty...
MEBCWD and gmcromp like this.
post #3 of 13 (permalink) Old 02-05-2019, 01:43 AM
Could be a bearing seizing up if it really is binding up. Otherwise loss of power is usally brushes or the armature windings.
difalkner likes this.
post #4 of 13 (permalink) Old 02-05-2019, 06:42 AM
difalkner's Avatar
First Name: David
Ditto on the bearing check, Charles. Have you taken covers off and done an inspection, taken belts off to see if the bearings or motor are binding?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #5 of 13 (permalink) Old 02-05-2019, 08:25 AM
I have one of these. Does this happen with all sizes of drums? I have had trouble with the smallest drum slipping on the shaft if I do not almost over-tighten the top knob. I think I burned it on an early try and it glazed the inside so it slips even easier now. If it does it with all your drums then I also vote for motor trouble. I have used the lifetime warranty on a 5" ROS and they were good on their word and fixed it for free on a timely basis. I like Rigid stuff for that reason.
sgcz75b likes this.
senebraskaee is offline
post #6 of 13 (permalink) Old 02-05-2019, 12:46 PM Thread Starter
Never had to use the spindles --- always have used the belt. When it binds smoke comes out the back. Sometimes it'll take off ok and others it needs a helping hand, I mean push. Other times it won't budge.
Went to Menards and got a disk/belt sander on sale for $60. Free after I redeemed my rebate card. Plus it's a 36 instead of a 24 inch belt. May use the 6" disk - never used the spindle part on the Ridgid.
HJ
Detroit Burbs
post #7 of 13 (permalink) Old 02-05-2019, 07:11 PM
Sounds like a bearing John. If you took it apart and removed the drive belt you could be sure. If one's stiff or you feel a bump as you rotate then it is hooped.
post #8 of 13 (permalink) Old 02-05-2019, 11:59 PM
I have that sander and I think it's direct drive like their contractor's saw.
I'd look at taking it apart and cleaning out the bearings and making sure the motor rotor turns freely.
Letting the magic smoke out of an electrical appliance is often fatal, and expensive to replace ;-)
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #9 of 13 (permalink) Old 02-06-2019, 12:51 AM Thread Starter
Paid a little more attention to it today. If it stops with the spindle in the up position or if I pull it up it starts right away with the switch and no help. When it's in the down position is where it hangs up. I got it going this evening and used it on about a dozen pieces with no problem. i have a big show this weekend so if I can make it til Thursday, I'm good. Then I'll start digging into it.
Went to Menards and found a disk/belt sander (36 inch - Ridgid takes a 24 inch belt) on sale for $60 - plus the 11% rebate - so I picked one up.
This one was bought when Ridgid was first starting their lifetime warranty thing and registration was so complicated that I never registered it, so it's not covered. Love the machine but I never used the spindle part of it so maybe the disk/belt may work better.
HJ
Detroit Burbs
post #10 of 13 (permalink) Old 02-06-2019, 05:56 AM
kp91's Avatar
First Name: Doug
Check with them anyway. Many states require warranties to be honored even without registering.
1 John 1:9
Fredericksburg, VA
kp91 is offline
Drum Sander tracking problem kp91 Tools and Woodworking 5 05-24-2017 09:02 PM
Ridgid EB44242 Oscillating Edge Belt/Spindle Sander Everend Tools and Woodworking 22 10-04-2016 06:58 AM
I Think I'm In The Market For A New Orbital Sander Jerry Bowen Tools and Woodworking 44 05-20-2016 03:13 PM
Ridgid R29302 Plunge Base Problem Adrenolin General Routing 10 06-04-2013 09:00 PM
Problem With PC 4212 Jig dppatt Jigs and Fixtures 4 05-27-2013 01:44 PM
