Removing Rust from a Jet Planer 6 inch - Router Forums
 8Likes
post #1 of 22 (permalink) Old 02-10-2019, 12:15 AM Thread Starter
First Name: lee
Default Removing Rust from a Jet Planer 6 inch
I have a friend which bought a Jet 6 inch planer for a job. He used it very little and it set under a Window AC unit in his shop. Well the bed and side piece rusted after a couple of years and he gave it to me because he did not want to deal with it. I covered it with my home made penetrating oil so it could soak into the rust. It has been soaking for about 6 months. I think I need to deal with it. What grit sand paper should I use? Should I start with 220 or coarser? There are no rust pits.
coxhaus is offline
post #2 of 22 (permalink) Old 02-10-2019, 12:20 AM
there are volumes of post and threads on removing rust w/ all the how to mechanicals here...
jmh1495 likes this.
post #3 of 22 (permalink) Old 02-10-2019, 03:34 AM
+1
Rossline is offline
post #4 of 22 (permalink) Old 02-10-2019, 08:03 AM
First Name: Art
You can sand it off but that won't get it out of the pores of the metal. Here is a short video testing a rust remover from Woodcraft. Since doing the vedio I have used it on a number of other things and have gotten to really like it.
mgmine is offline
post #5 of 22 (permalink) Old 02-10-2019, 08:49 AM
Nickp's Avatar
First Name: Nick
I would use wet/dry paper...the more coarse the paper the more work to finish it. Try a little bit higher grit (320) and see the effects, then drop down if you think it's okay. Don't use an ROS...it will leave a boatful of swirlies...
Use your favorite cutting/penetrating oil, put a block behind the paper and have at it. Then use higher and higher paper to finish to a polish.
Nick
Nickp is offline
post #6 of 22 (permalink) Old 02-10-2019, 10:00 AM
Nickp's Avatar
First Name: Nick
...how about a pic of what it looks like...? May get better responses...
Nick
Nickp is offline
post #7 of 22 (permalink) Old 02-10-2019, 10:21 AM
Nickp's Avatar
First Name: Nick
...here's the SDS on the RustFree product...note the main ingredient is phosphoric acid...30%
http://go.rockler.com/msds/Boeshield-Rust-Free-SDS.pdf
ATF and Acetone for me... Stick's Mix Ole No. 7...
@Stick486 ...?
Nick
Nickp is offline
post #8 of 22 (permalink) Old 02-10-2019, 01:25 PM
difalkner's Avatar
First Name: David
When I restored my PM66 table saw I did it both dry and wet. Here's the story if you want to check it out - Restoration of PM66 table saw.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #9 of 22 (permalink) Old 02-10-2019, 02:47 PM
kp91's Avatar
First Name: Doug
I feel your pain. This year has been freeeeeeeezing cold, then we get a warm flow out of the gulf and it goes up to a rainy 60 degrees. This has caused a lot of condensation on my tools while I am away, leading to rust on some of them. I hate wasting a day getting rust off of everything!
I use the Boeshield products, Rustfree and T9
https://boeshield.com/products/
DesertRatTom likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #10 of 22 (permalink) Old 02-13-2019, 12:00 PM Thread Starter
First Name: lee
Here are a couple pictures. I have soaked the rust with Stick's 50% Acetone 50%ATF over the last few months so I think the rust is soft and well soaked.
I am now thinking skipping the 220 wet dry paper and going straight to 320 wet or dry or maybe just a green scrubber. I have had good luck with 5% vinegar in the past. I don't if it would be better than the phosphoric acid...30%.
coxhaus is offline
Hello all Weh2k9 New Member Introductions 13 05-02-2018 05:45 PM
First box joints Debbie Show N' Tell 39 04-10-2018 06:35 PM
10 inch bandsaw Rikon vs. Jet Kelly Rittgers Tools and Woodworking 9 07-10-2012 02:17 PM
Delta 12 1/2 inch planer Dust Collector Dakota Kid Tools and Woodworking 3 03-13-2012 10:53 AM
Thin stock to 1/8 inch on Planer ACV Tools and Woodworking 6 10-21-2007 11:13 PM
