Best wood working - Page 4 - Router Forums
 21Likes
post #31 of 34 (permalink) Old 02-21-2019, 11:33 AM
First Name: AL
I have to vote for the Rikon. I have my 14" 10-325 for over 10 years and has served me well. Researched and tested a number of saws, including Laguna, and as a beginner i chose the Rikon. And after 10 years it is working great. I used it all the time. Resawing, trimming, preparing wood for turning ect. My son is into woodworking and just purchased his first bandsaw. The 14" rikon 10-326. It is perfect for him.
sgcz75b likes this.
Buce is offline
post #32 of 34 (permalink) Old 02-21-2019, 02:12 PM
sgcz75b's Avatar
First Name: Steve
So far, I've found nothing that can beat the Grizzly 513X2 for features and values @ 1380. I may spring for the additional foot and motor brake as that only adds about $300.00 to the price. The mobile stand adds $90.00 and an additional 2-year warranty for about $30.00 brings it to a three-year warranty total.
That's around 1900 give or take a little to get it in my shop. Not bad when I originally had decided that $2500.00 was my budget. I can get three good blades for $150-200, a Carter Stabilizer for 1/4 inch blades at around $70. So still about $21-2300.
Those are numbers I can handle. Not so for the Powermatic PM1500 at 32-3400. I prefer the Grizzly for my perceived bigger bang for my bucks over the rest.
However, if someone wants to give me a Powermatic 1500 or Laguna Italian LT16 HD I'll gladly accept. But I'm not buying them.
Steve
Steve
honesttjohn likes this.
"What can be asserted without proof can be dismissed without proof." Christopher Hitchens
sgcz75b is offline
post #33 of 34 (permalink) Old 02-21-2019, 06:53 PM
Hope you'll tell us about your new saw once you've used it a bit.
One final little item from me. I have found that my blades work a little better and with less odd noises when I use a stone to lightly round over the back edge of the blade before use. Makes turns a little easier and might reduce wear and tear on your guides. I found a stone mounted on a stick (pix) that makes this easy. I do maybe 4-5 revolutions of the blade (you hear the click of the weld), on each edge. The stick model is cheaper than messing up a more expensive stone. I think I found this at Rockler.
Nickp likes this.
DesertRatTom is online now
post #34 of 34 (permalink) Old 02-21-2019, 10:33 PM
sgcz75b's Avatar
First Name: Steve
Good idea. I was watching a youtube where someone (it might have been Alex Snodgrass) recommended the same thing.
To tell the truth, I'm glad I've decided on the 513X2. After a while all the research runs together into a quagmire of second guessing and more research.
After I get it and play with it a while using my Dustopper and shop vac for dust collection, it will be time to look at a bigger and more convenient system. Until iIfind a good resting place for the bandsaw and table saw though, I'm reluctant to do more than run hoses. But I can go ahead and aquire the guts of the system that will work now and later.
I know you're quite knowledgeable and a voice for DC, so again, you're welcome to give me your advice.
Thanks again.
Steve
sgcz75b is offline
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
I'm new to wood working woodworking15 New Member Introductions 6 02-02-2015 11:09 PM
Wood Working TV Program Tagwatts1 General Routing 6 07-24-2012 04:03 PM
Timber Working with Wood, Brisbane 2012 japa62 Shows & Events 0 05-15-2012 04:06 AM
First wood working Fourleftpaws Show N' Tell 19 06-13-2011 01:21 PM
