Jigsaw Grease - Router Forums
 43Likes
post #1 of 30 (permalink) Old 02-17-2019, 05:21 PM Thread Starter
Default Jigsaw Grease
I have a 1958 Power-Kraft (Montgomery Ward) jigsaw that I got for my 11th birthday and I am not restoring for my grand-kids to use. Unlike what folks call a jigsaw today, which I call a saber-saw, my jigsaw is a stationary tool. It is in good shape but the grease in the gear case has turned to sludge and needs to be replaced. The manual says "The entire pulley mechanism is packed with special grease and lubricated-for-life." I guess they never thought it would live to be 60 years old!
Anyway, I am trying to figure out what to put in the crankshaft housing now that I have cleaned it out. I have replaced the seal on the shaft so it would hold either grease or oil but I am torn which to use. Suggestions welcomed!
sreilly and peterbata like this.
senebraskaee is offline
post #2 of 30 (permalink) Old 02-17-2019, 05:44 PM
mimac's Avatar
First Name: Brian
I think I would go with white lithium grease but I imagine wheel bearing grease would work as well.
radios likes this.
mimac is offline
post #3 of 30 (permalink) Old 02-17-2019, 05:55 PM
sgcz75b's Avatar
First Name: Steve
I would definitely use grease, not oil. This Lucas oil product has never let me down and is available at Home Depot and most auto stores for 5 bucks and can be used everywhere you need grease.
MEBCWD and roxanne562001 like this.
"What can be asserted without proof can be dismissed without proof." Christopher Hitchens
sgcz75b is offline
post #4 of 30 (permalink) Old 02-17-2019, 06:09 PM
jj777746's Avatar
I would use the before mentioned Lucas grease. Just the shot for an old jigsaw or any old machine. James.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #5 of 30 (permalink) Old 02-17-2019, 06:35 PM
JOAT's Avatar
First Name: Theo
That would be what is called a scrollsaw by the kids nowadays. I would say any quality grease will likely work.
JOAT is offline
post #6 of 30 (permalink) Old 02-17-2019, 07:03 PM
Valvoline™ Full Synthetic Grease
post #7 of 30 (permalink) Old 02-17-2019, 07:15 PM
mimac's Avatar
First Name: Brian
Bear grease. Contains Whistles and pepper.
mimac is offline
post #8 of 30 (permalink) Old 02-18-2019, 03:08 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
like this one?
https://www.google.com/imgres?imgurl...act=mrc&uact=8
it would be a scroll saw, or even a fret saw in some places.
jj777746 likes this.
sunnybob is offline
post #9 of 30 (permalink) Old 02-18-2019, 11:51 AM
Oil is more efficient at transporting heat away from bearings but is much harder to hold in. Heavy equipment uses 10 weight oil in the diff housings for that reason. If your gear box never got hot then that isn't a concern.
post #10 of 30 (permalink) Old 02-18-2019, 01:16 PM
First Name: Frank
This machine is an older version and you have to be as old older than I am to remember seeing these machines. I would use a grease that will lubricate and stick to the moving parts and would dissipate heat quickly. I would use a silicone, synthetic type of grease. I do not know what the wear factor is here. This is another reason to use this type of grease. You can by TriFlow Synthetic Grease with Teflon: 3oz size at Wallmart stores. It is a good quality grease for parts that are fast-moving and can create heat. The White Lithium grease may be fine, but I stick pretty much with Silicone type grease for all of my power tools. I have some old drill presses and two hammer drills that I have never used anything else on.
Just my preference.
roxanne562001 likes this.
Tagwatts1 from Utah
Tagwatts1 is offline
best jigsaw tables laurencewithau Tools and Woodworking 6 05-23-2017 07:45 AM
150 Drops of Oil ? herrwood Tools and Woodworking 33 09-02-2015 02:07 PM
Mounting Bosch Jigsaw to Router Baseplate - finished Ladd Table-mounted Routing 4 02-06-2008 05:47 PM
