water sharening stone - Router Forums
 6Likes
  • 5 Post By Cherryville Chuck
  • 1 Post By Stick486
post #1 of 6 (permalink) Old 02-17-2019, 07:54 PM Thread Starter
First Name: Peter
Default water sharening stone
Hi
may I ask if the sharpening stone in the attached picture is faulty or not? It has the same making in the centre each time it is wet. The whitish marking goes from the side to the surface. It still flattens ok.
Thanking you in anticipation
Peteroo
Peteroo1 is offline
post #2 of 6 (permalink) Old 02-17-2019, 08:04 PM
mimac's Avatar
First Name: Brian
Looks like a King stone. If it works then it's ok
mimac is online now
post #3 of 6 (permalink) Old 02-17-2019, 11:02 PM
It may be salts in your water that have accumulated in the particle matrix. It's best to either use distilled water or like I do put the stone in a mason jar filled with water and keep it that way. If it's salt residue it's because the water you put on it dries out leaving any mineral behind. I know I've read whether that can be harmful or not but I don't remember anymore. Maybe it is and maybe that's why I decided to keep mine immersed all the time. There may be some info on Lee Valley's site about it.
post #4 of 6 (permalink) Old 02-18-2019, 04:46 AM
listen to Charles...
MEBCWD likes this.
post #5 of 6 (permalink) Old 02-18-2019, 12:31 PM
Zippity's Avatar
Country: New Zealand
First Name: Ron
I've just read that wetstones should NOT be stored in water.
It can damage the stone.
Zippity is offline
post #6 of 6 (permalink) Old 02-18-2019, 01:57 PM
mimac's Avatar
First Name: Brian
Lee valley makes a stone pond used for storing water stones in. The only exception they mention is to not store stones with an attached wooden base.
mimac is online now
Home Renovation TRN_Diesel Project Plans and How To 99 07-26-2014 10:25 PM
Local ties to Australia for our members down under. jd99 Lobby 2 03-11-2010 05:55 AM
Shop Vac Water Filter Soapdish Tools and Woodworking 15 01-25-2010 12:22 PM
Repairing leaking hot water tank TRN_Diesel DIY and Renovation 43 01-15-2010 12:15 AM
Help: Hot Water System Gone Wild morgantruce DIY and Renovation 8 12-27-2009 07:40 AM
