220 extension cord for tools - Page 2 - Router Forums
 90Likes
post #11 of 74 (permalink) Old 02-24-2019, 03:01 PM
OCEdesigns's Avatar
First Name: Chad
In simple terms as long as the extension cord is rated for 50 amps your equipment will be fine. I made a 10' and a 25' cord for my shop also. I have welders, and plasma cutter that I use all over.
DaninVan, mjadams61 and sgcz75b like this.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #12 of 74 (permalink) Old 02-24-2019, 03:23 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
Being the electrical simpleton that I am, I've got it! Thanks
OCEdesigns likes this.
"What can be asserted without proof can be dismissed without proof." Christopher Hitchens
sgcz75b is offline
post #13 of 74 (permalink) Old 02-24-2019, 05:16 PM
The heavy gauge extension cord is an option. The code guide I use says that if a run is longer than 75 feet it's a good idea to go up one wire size. Although your welder plug is a 50 amp it is likely being fed with a 40 amp breaker. I've never figured out or heard a reason for this discrepancy. Truthfully I can't ever remember seeing a 50 amp breaker. Wire size for 40 amps is #8. If you have longer than 75 feet of total run you might consider going to #6 IF you intended to pull full load at the total distance. But the largest load you are likely to pull with a power tool that is portable enough to wheel out on your drive way is going to be 20 amps which would only require 12 gauge or on a really long run 10 gauge which is normally good for 30 amps. So an 8 gauge extension cord would be ample for any load you are going to put on it. As for adapting to different ends I wouldn't bother. I would just put the same end on the cord to all your tools, i.e. a 20 amp if that is the largest single load.
post #14 of 74 (permalink) Old 02-24-2019, 05:39 PM
Pretty sure you don't want to run your equipment off a 50A or even a 40A breaker. For starters all the downstream components need to be sized for the size of the breaker. The issue being that an issue with a 15A tool won't trip the massively oversized breaker, no matter what the size of the cable. An actual short probably would pop it, but I don't think you want to be part of the cct. if that happens!.
50A at 220 v is going to be a memorable experience...if you actually survive it.
You need to have a short run of #6 into a 2pole mini panel with a 2 pole 15 or 20A breaker, then you can wire in a couple of duplex receptacles. Each leg of the 220V cct would feed a separate receptacle.
As I mentioned earlier you need 3wire plus ground #6 cable if it's a 50A cct. The third wire is White and will be the Neutral for either side of your two 120Vccts. In theory you shouldn't be using 220Vand 120V plugs on the same cct. as the load can theoretically be unbalanced. Maybe somebody can explain itbetter(?)
Red.......Phase 1. 120V
Black.....Phase 2. 120V
White....Neutral...return wire for the 120v ccts.
Green... mandatory! up to the receptacle, but not necessarily req'd by Double Insulated tools. Factory installed two prong plugs.
DaninVan is online now
post #15 of 74 (permalink) Old 02-24-2019, 05:56 PM
Re what Charles said; if it wasn't clear. The breaker determines the MINIMUM capacity of ALL components downstream but you can INCREASE the size of the components downstream up to the breakers' capacity.
For example; you can use 20 amp component on a 15 A breaker but you can't use 15A components on a 20A breaker. It's easier to just use the correct sizing. Some better quality receptacles will be '15Amp-20Amp Rated'///in other words the blade configuration will accept either male plug and the internal construction will be a lot more rugged.
post #16 of 74 (permalink) Old 02-24-2019, 06:03 PM
I probably muddied the water with that last one...
To clarify my own comment, If you draw 20A on a 15A breaker it'll just pop it.
An example might be a portable compressor; they're notorious for popping 15A breakers, especially if you plug them into a general purpose wall receptacle which probably already has lights and stuff running on the cct.
ie you're definitely going to be over 15A on start up.
post #17 of 74 (permalink) Old 02-24-2019, 06:04 PM
mjadams61's Avatar
First Name: Marlin
Are you planning on using that outlet for welding or anything that requires a 50amp breaker? If not you can always step down the breaker to the appropriate ampreage you need to run your bandsaw. It does not matter if the wire is bigger than you need but it does matter if the wire is smaller than you need. So if you only need a 30amp breaker put in a 30 amp breaker.
mjadams61 is offline
post #18 of 74 (permalink) Old 02-24-2019, 06:10 PM
Excellent option, Marlin!
mjadams61 likes this.
post #19 of 74 (permalink) Old 02-24-2019, 06:39 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
OK. I'm confused again. I do have a stick welder. While I don't approach 50 amps in use, probably 40 at the most, doesn't having a larger amp breaker (and it is a 50 amp breaker) mean that any less amperage requirements will not overload the circuit?
(Grizzly bandsaw specs
Full-Load Current Rating............................................ ....... 19A at 110V, 9.5A at 220V
Minimum Circuit size............................. 30A at 110V, 15A at 220V?
If a 110 15 amp breaker gets 20 amps of demand, doesn't it trip? I also know from experience that a short in a lamp wire will trip a 15 amp breaker even if nothing else is on that circuit.
I'm not understanding why I should NOT use the existing 50 amp breaker, with 6-8 gauge "S" wire and a 50 amp female plug to connect 220 tools. Remember the extension cord for my purposes only needs to be 20-25 " at most and at no time will more than one tool be in use.
I want a power cord that will let me use my welder and power tools. Is that not possible?
Thanks again.
Steve
Cherryville Chuck likes this.
sgcz75b is offline
post #20 of 74 (permalink) Old 02-24-2019, 06:44 PM
mjadams61's Avatar
First Name: Marlin
Or if you want to keep the option of having a outlet for welding you can make a seperate small panel out of a outdoor panel for a single breaker where you can plug it to the 220 volt 50 amp circuit and have a outlet come off that panel you made with a receptacle to fit your bandsaw. When you need it plug it up when you need to weld unplug it. Have it mounted near your 220v 50 amp recepticle.
https://www.homedepot.com/p/Square-D...RBCP/100194428
DaninVan likes this.
Frankenstein Lives!! Jet 1014 Extended gdonham1 Woodturning and Lathes 5 01-24-2019 12:09 AM
DIY Extension Cord MT Stringer Show N' Tell 9 12-15-2014 08:49 AM
220 Volt Extension Cords jbullockusanet Shop Safety 55 08-09-2014 01:36 PM
Extension cord + power strip: advice needed xvimbi Tools and Woodworking 15 07-16-2010 11:55 AM
Router Table Extension - Attachment and Alignment GarethR Table-mounted Routing 1 11-20-2009 01:47 AM
