220 extension cord for tools - Router Forums
 90Likes
post #1 of 74 (permalink) Old 02-24-2019, 07:50 AM Thread Starter
sgcz75b's Avatar
First Name: Steve
Default 220 extension cord for tools
I have a 220 50 amp circuit in my shop for welding which I will use for my 220 bandsaw. Is there any reason not to make a 220 extension cord that would make it easier to change out plugs?
Maybe a gang box with a couple of plugs? I wouldn't be running two tools at a time, but the convenience would be great.
I'm sure someone here has done that so would you give me some tips?
Thanks.
Steve
"What can be asserted without proof can be dismissed without proof." Christopher Hitchens
sgcz75b is offline
post #2 of 74 (permalink) Old 02-24-2019, 08:03 AM
ger21's Avatar
First Name: Gerry
As long as you use wire capable of handling 50 amps, then no problem.
Ger
www.cncwoodworker.com
ger21 is online now
post #3 of 74 (permalink) Old 02-24-2019, 10:18 AM
RainMan 2.0's Avatar
Thatís the first thing that I thought .
The wire in the extension cord would have to be rated for 50 amps as you mention, otherwise if a short occurred ,the breaker wouldnít trip
DaninVan and jj777746 like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 74 (permalink) Old 02-24-2019, 10:34 AM
First Name: Sam
Voltage and current rating of cord should meet or exceed your current and voltage.
Samandothers is offline
post #5 of 74 (permalink) Old 02-24-2019, 12:03 PM
I just did exactly what you want to do. I added a 20 amp plug wired from my welder plug. I only used 12 gauge wire and it's not a great idea but it's for my planer and I'll be standing next to it the whole time it's running so I think I can manage the risk. The best way to do what you suggest is to take the wire from the welder plug and run it into a sub panel. Some sub panels allow you to run a wire out that is direct and not fused. That could allow you to hook up to the welder again without going through another breaker other than the the one in the main panel. That would allow a 30 amp sub panel which could be used for the tools you want to run as none of them should be greater than 20 amps. That should be code compliant I think.
jj777746 and sgcz75b like this.
post #6 of 74 (permalink) Old 02-24-2019, 12:11 PM
More to the point, the equipment at the business end is going to be seriously shortchanged on the voltage it needs to operate; expect the cable to get really hot and self destruct if the equipment is operating at near the rating of the breaker. #6-3 wire/grd...
https://www.ebay.com/itm/50-6-3-SOOW...-/273520619202
RainMan 2.0 and jj777746 like this.
DaninVan is offline
post #7 of 74 (permalink) Old 02-24-2019, 12:11 PM
mjadams61's Avatar
First Name: Marlin
A friend of mine had the same issue so made a couple of short 2 ft extension 220volt cords. Same male end to fit the wall 220volt receptical but different female ends on the cords to fit the different 220 machines.
tooler2, RainMan 2.0 and sgcz75b like this.
mjadams61 is offline
post #8 of 74 (permalink) Old 02-24-2019, 12:18 PM
Charles; maybe a couple of inline fuses in a made-up junction box, plugged into the 50A receptacle?
https://www.amazon.ca/Etopars-Holder...SIN=B0716JBMWJ
DaninVan is offline
post #9 of 74 (permalink) Old 02-24-2019, 01:35 PM
Knothead47's Avatar
Good thread. What is the maximum length for such a cord? We are talking about a few feet here but curious. I know that regular cords have a limit before a voltage drop.
sgcz75b likes this.
John T.
Knothead47 is offline
post #10 of 74 (permalink) Old 02-24-2019, 01:43 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
I'm not sure I understand so let me state what I have. It's a 50 amp breaker with a 220 outlet using an old welder outlet.
I've ordered a plug (50 amp) that matches the outlet receptacle.
Now I need the wire and outlet receptacle (or receptacles) at the other end of the extension cord to plug in my 220 tools.
I see 25' welding extension cords on Amazon with 8 ga. wire, but of course, the plugs don't have the older style of my 220 receptacle.
I was hoping to get a 20-25' extension cord to be able to go outside my shop and work with a future planer or lathe.
Are you saying that if I plug a tool into an extension cord of 8 ga.wire that I could damage my tool?
Sorry, but electrical situations are not my area of expertise, so your help is appreciated. Pretend I know nothing about this situation so explain in simple terms.
Thanks.
Steve
sgcz75b is offline
Frankenstein Lives!! Jet 1014 Extended gdonham1 Woodturning and Lathes 5 01-23-2019 11:09 PM
DIY Extension Cord MT Stringer Show N' Tell 9 12-15-2014 07:49 AM
220 Volt Extension Cords jbullockusanet Shop Safety 55 08-09-2014 12:36 PM
Extension cord + power strip: advice needed xvimbi Tools and Woodworking 15 07-16-2010 10:55 AM
Router Table Extension - Attachment and Alignment GarethR Table-mounted Routing 1 11-20-2009 12:47 AM
