Kreg Adaptive Cutting System - Page 2 - Router Forums
 18Likes
post #11 of 26 (permalink) Old 02-27-2019, 03:58 PM
roofner's Avatar
First Name: Gary
If you look at the Triton track saw and kreg they look a lot alike . If I was guessing triton is the manufacture.
roofner is offline
post #12 of 26 (permalink) Old 02-27-2019, 05:13 PM
RainMan 2.0's Avatar
This is interesting. I haven’t found a Kreg product that I didn’t like . Unfortunately I already have a track saw
I donít always insulate , but when I do . Ok , I never insulate
RainMan 2.0 is offline
post #13 of 26 (permalink) Old 02-27-2019, 11:01 PM
twmv86's Avatar
First Name: Tim
i have the accucut but just use a circular saw. guess its too much ask for kreg to figure a way make it where you can use the accucut track on their new stuff. lots of new stuff on that table i'd like but no way i can swing 900 bucks
Certified Recliner Operator
twmv86 is offline
post #14 of 26 (permalink) Old 02-28-2019, 05:04 PM
roofner's Avatar
First Name: Gary
Here is a link that shows a link between Kreg and triton back in 2011.
https://kregjig.ning.com/forum/topics/kreg-triton
roofner is offline
post #15 of 26 (permalink) Old 03-04-2019, 08:19 AM
This week Grizzly has it's track saw on sale for $195. Includes a 55" track. Another 55" piece is $71. Got me thinking.......
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #16 of 26 (permalink) Old 03-04-2019, 09:02 AM
Originally Posted by vchiarelli View Post
I'm with you Dan - a home made straight edge made for a specific saw. Have on that's 8' and one that's 4', labelled for a specific saw.
Used one like that for many years with no problems. Mine though was made using 1/8" tempered Masonite for the base, less error IMHO in lining up the pencil marks. I used a 36" steel rule with ruler stop to mark the cut line on either side of the sheet, took only a couple of minutes to mark the lines and clamp the guide in place. Finally retired it after I bought a track saw - mixed emotions about that bu mostly positive (once the price shock wore off) - and actually had to move the fence over a couple of time so that I could cut a fresh edge, finally ran out of clamp surface on the back side of the fence.
tomp913 is offline
post #17 of 26 (permalink) Old 03-11-2019, 12:41 PM
Ended up ordering the Grizz track saw and an extra piece of track. Not only was it on sale, but also got 10% more off with the veterans discount. We shall see!!!
RainMan 2.0 and sgcz75b like this.
HJ
Detroit Burbs
post #18 of 26 (permalink) Old 03-12-2019, 03:35 PM
Grizz track saw got here. Nice solid saw. Track seems pretty good. Also came with clamp on hold down to keep it from coming off the track and a stop block for cuts less than 100% of the material width. Of course, since I never had or used one before I have nothing to compare it to. The one thing I have concerns about is the 6 1/2" blade, but I don't plan on cutting thick stuff anyway. Came with a 48 tooth carbide tipped blade. Cut some 5/4 oak planks with no problems. Not too shabby for under $175.
twmv86 likes this.
HJ
Detroit Burbs
post #19 of 26 (permalink) Old 03-15-2019, 12:38 AM
twmv86's Avatar
First Name: Tim
wow that looks great. i ordered just the kreg folding table legs today and will make my own top.i wish i could incorporate my accu cut track with some of their new toys but no luck. i also found out their bench clamps exert too much pressure to use in t track wont track.
i had bought some thick aluminum last summer to make a homemade version of these, and some 3/4 bar to drill and tap to make a couple adjustable dogs. looks like those two things, some plain dogs and a couple holdfasts will have to suffice. even bought can of flex seal to dip the ends of the clamps in after i heat and bend them a bit. i guess that will work. will see
jj777746 likes this.
twmv86 is offline
post #20 of 26 (permalink) Old 03-19-2019, 04:47 PM
twmv86's Avatar
First Name: Tim
if any po folk like me were thinking of only buying the legs of this system and making your own top be advised. all of the hardware needed to mount this on their top isnt sent out with the folding legs. some of it comes preinstalled in their top. they send out 6 u-bolts that are mounted from above in recesses shown in the pic of their top. its 3/4 mdf for $149. kreg doesnt think anyone who buys only the legs needs instructions of any kind in the box. their "comprehensive" hardware pack came with 6 u-bolts, 12 nuts & 4 u-brackets. they did put these sweet chinese finger puzzle looking things protecting the threads on the bolts for the adjustable legs so theres that.
while its not impossible to think i can lay a homemade top upside down and try and figure out where to drill to bolt from above i seriously doubt it will be on the first few attempts. with their top there are bolts preinstalled that you gives you a starting point that i wont have unless i knuckle under and buy their over priced top. theres only 8 different locations i have to guess where to attach things. this may not seem like a daunting a task to most of you but im not liking this at all. aint gonna be as easy i had hoped. the fact there was ZERO instructions in the box really stinks
Name:	4 bolts.jpg
twmv86 is offline
Which bits... a deep rabbit hole... AshleyJ Router Bits - Types and Usage 15 03-10-2018 08:36 PM
Kreg precision router table system Duane Bledsoe Tool Reviews 11 07-28-2015 02:00 PM
Kreg router plate leveling system masonsailor Table-mounted Routing 1 03-09-2014 08:59 AM
Profile Cutting Options BobCAD CAM aldepoalo CNC Routing 0 02-08-2012 10:49 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
