Wood laminate question - Router Forums
 9Likes
  • 1 Post By honesttjohn
  • 5 Post By ger21
  • 2 Post By honesttjohn
  • 1 Post By MEBCWD
post #1 of 5 (permalink) Old 02-28-2019, 07:10 AM Thread Starter
Default Wood laminate question
I've been approached to make a wall badge (a Polish Eagle, of course) for the Polish American Community of Toledo's HQ. It will be round and somewhere around 36-40 inches in diameter. The ready made blanks in that size are not thick enough. I need at least 1 1/4" thick piece of stock. So I'll have to glue one up. Now, is it better to use 5/8 x 18 x 36 panels, 5/4 x 6 boards, 1 1/2" strips glued edge side up, or ??????. This will be predominately displayed so it's got to have limited warpage and no future cracks. What's the best way to go?
Danman1957 likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #2 of 5 (permalink) Old 02-28-2019, 09:32 AM
ger21's Avatar
First Name: Gerry
The most stable would be the 1-1/2" strips, but it would also be the worst look. But that depends on the grain, species, and finish.
The 5/8 x 18 x 36 panels would be the worst choice. I think you'd have a hard time getting them clamped, and you'd see the glue line or even a gap if you cut more than 5/8" deep.
If it's hardwood, you'd need 6/4 thick material. 5/4 is roughly 1-1/4" in it's rough sawn state, and finishes closer to 1".
I'd go with the 1-1/4" thick, 4"-6" wide. Narrower is better. Quartersawn is best.
Ger
www.cncwoodworker.com
ger21 is offline
post #3 of 5 (permalink) Old 03-01-2019, 09:19 AM
First Name: Art
How deep will the cutting be? I ask because there will be edge showing if it goes deeper than the thinnest top piece. To get something that thick you will have to ether go with strips or several layers of wood. I don't think the layers will work unless you stsrt with a large flat panel like MDF. With something that large it will be difficult to make sure that there are no voids in the middle which will show when carved.
mgmine is offline
post #4 of 5 (permalink) Old 03-01-2019, 10:09 AM Thread Starter
Looks like I'm going to try and glue up 5/4 ( a full 1.25"). I've got some knot free select grade pine in both 4 and 6 inch widths that carves pretty good. I can make the model a little thinner and use a dish layout and still have it look good.
MEBCWD and Herb Stoops like this.
HJ
Detroit Burbs
post #5 of 5 (permalink) Old 03-01-2019, 01:57 PM
MEBCWD's Avatar
That will be the best way to go, glue up 4" to 6" wide by 1.25" to 1.50" thick wood. 36" to 40" diameter is a decent size so the thicker the better. Remember to alternate grain direction in the glue-up to keep cupping to a minimum.
The thicker you make it the more detail you can have in the model and if you use a flat bottom dish you can get the most detail.
I would consider using a hardwood like oak, maple or walnut, instead of the pine, it might cut cleaner and leave less cleanup. You could submit 2 bids, one for pine and one for hardwood, and let them decide.
honesttjohn likes this.
MEBCWD is offline
Exterior wood Treatment dattashri The Finishing Touch 3 05-14-2012 11:37 AM
Wood Burning Stove - question for stove users bretwalda Lobby 12 02-20-2012 01:43 AM
laminate waiting time question MDS Table-mounted Routing 6 04-22-2011 06:57 AM
How to identify wood species: allthunbs Tools and Woodworking 11 12-04-2008 12:28 PM
