Dedicated mortiser vs DP mortise attachment - Router Forums
 24Likes
post #1 of 13 (permalink) Old 03-01-2019, 12:08 PM Thread Starter
Default Dedicated mortiser vs DP mortise attachment
I'm in the process of building a night stand for my wife. Two nights ago I was fighting with a machine and then got called in for supper and came out and made a really rookie mistake because my brain wasn't fully involved in what I was doing. I cut the crosspieces for between the legs and forgot to add on the lengths of the tenons. I had already drilled the mortises for the top pieces into the legs with my drill press mortise attachment so I was committed to tenons already. I thought that it wasn't a start over type catastrophe, I'd just switch to floating tenons instead. I just needed to mortise the ends of the cross pieces to match.
I had just finished reading an article in FWW about one of the authors wanting to use his dedicated mortiser for a project but it didn't have enough height capacity. My screw up highlighted a major difference between using a dedicated mortiser and using a drill press mortise attachment. If someone is thinking about buying one opposed to the other this is something they may want to consider first. A dedicated mortiser has a height limitation of around 6-8 inches it looks like (I couldn't find a spec on that in their ads). A floor standing DP with attachment has a height limitation of a little over 3 feet if you turn the table to vertical or move it out of the way. This allowed me to use the DP to make mortises in the ends of my 13 1/2" long pieces instead of drilling and chiseling.
Name:	DP mortise attachment.jpg
post #2 of 13 (permalink) Old 03-01-2019, 04:55 PM
Nickp's Avatar
First Name: Nick
Excellent point, Charles...not so obvious until it's needed...
Nick
Nickp is offline
post #3 of 13 (permalink) Old 03-01-2019, 05:21 PM Thread Starter
I hadn't thought about it before.
DesertRatTom likes this.
post #4 of 13 (permalink) Old 03-01-2019, 07:49 PM
Good thoughts. Is it rigid enough to stay vertical with hard wood? Been thinking about getting the DP attachment beause I just won't use a mortising machine that much.
post #5 of 13 (permalink) Old 03-01-2019, 08:58 PM Thread Starter
That's white birch that's 30 years old I'm using it on Tom so yes. Once the points enter the wood the top isn't going to move. A dedicated mortiser will set you back around $500, the attachment was $130 I think, but 25 years ago roughly. BJ used to say why have another machine taking up room when you already have a DP. That was my sentiment too but now I realize that the DP has far greater range so to me that makes the attachment an even better deal. The attachment takes 5 minutes or less to mount BTW. There is a clamp ring on the yoke that fits on the base of the quill, above the chuck. Mine was a Delta attachment for a Delta DP so no issues with fit but it came with a bushing for a different size quill and it sounds like the two sizes are pretty standard.
Danman1957 and DesertRatTom like this.
post #6 of 13 (permalink) Old 03-02-2019, 12:28 AM
Are you using square tenons in the spreaders instead of round?
Herb Stoops is offline
post #7 of 13 (permalink) Old 03-02-2019, 01:13 AM Thread Starter
Yes. I used a 1/2" chisel and overlapped the holes to about 3/4" long so I cut some rectangular stock to match. If it's a little tight it only takes a minute to hand chisel out one end. None have been too loose yet but if they are I use paper or cotton cloth to tighten them up if needed. Cotton and paper will both absorb the glue and become part of the joint.
post #8 of 13 (permalink) Old 03-02-2019, 07:10 AM
Stoneface's Avatar
First Name: Frank
I have the opportunity to purchase a usd Delta mortising machine for $150 with 4 drills. New it is $352 without drills. I cannot justify the great buy. I have the drill press attachments and works for what I need.
Frank
Frank
Stoneface is online now
post #9 of 13 (permalink) Old 03-02-2019, 08:08 AM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
those of us with Shopsmith's or other multi-tools don't have the floor as a limit!!!
It's the wall that's the limiting factor.
just sayin'
smitty
smitty10101 is offline
post #10 of 13 (permalink) Old 03-02-2019, 10:37 AM
Thanks,I'm going to look into that. I have a WEN DP, which is identical to the Jet, so I can probably get the one for the JET. Sounds like it would be a good idea to contact the manufacturer to be sure. Thinking about it, I suspect I'll want the chisel bits in 3/8ths and one half inch.
I recently bought the Rockler round mortise and tennon jig that uses the pre made tennons, but I'd like to be able to make through tennons as well.
For Sale: PC Dovetail Jig & Delta DP Mortise Attachment greenacres2 Woodworking Classifieds 7 02-15-2014 08:53 AM
Question About Chisels Jerry Bowen Tools and Woodworking 36 12-29-2012 09:21 AM
Type Of Mortise Chisel To Square Slot Gaia Tools and Woodworking 50 08-29-2011 02:17 PM
Cross Slide Vise for Benchtop Mortiser Michael H Tools and Woodworking 29 10-21-2009 09:27 AM
TS / Router / Mortise Combo PART1 kolias Jigs and Fixtures 1 05-04-2009 06:52 AM
