Adjusting Fence Parallel with Miter Slots - Page 2 - Router Forums
 7Likes
post #11 of 15 (permalink) Old 10-07-2020, 12:11 PM
thanks for the info, useful
JosephGabb is offline
post #12 of 15 (permalink) Old 10-07-2020, 01:09 PM
For no particular reason, I popped for the Woodpecker dial caliper in the picture. About $100, but I find it's so easy to use that I use it more often. It showed me there was about .004 variation in the face of the fence. Not much of an error, but I needed to take it into account setting the outfeed end.
I bought a Laguna Fusion 10 inch saw, found one of the wings was warped just about one mm, so I couldn't get the table really flat. Called Laguna (about 2 hours away in Newport Beach area and they said bring it in. So I did and they replaced the entire saw with a new one they'd set up perfectly! They even used a huge machined straight edge and feeler gauges. The top had one small area off to the right, near the end that was .015 low, which is basically perfectly flat. In case anyone wonders why I LOVE Laguna tools. Here's the picture, pretty, isn't it. Definitely an indulgence though.
Name:	woodpecker fence gauge.jpg
peterbata likes this.
post #13 of 15 (permalink) Old 10-07-2020, 06:08 PM
peterbata's Avatar
First Name: Peter
@DesertRatTom . She's a real beauty Tom!
It's better to burn out than to fade away!
peterbata is offline
post #14 of 15 (permalink) Old 10-07-2020, 06:47 PM
First Name: Steve
I used a dial caliper and a MAG-DRO Mitre Slot Caliper Base (available from Amazon). You do not need an expensive dial caliper biter slot tool. This one is plastic with tabs to hot it tight to miter slot. I set the blade and miter slot about .00015 to .0002. You will need to mark the blade tooth when the in-feed is measured and then blade is rotated for the second reading. You should not use the blade using different reference points. Always the same spot. . You the set the fence parallel to miter slot. I set mine +.0004 ( the thickness of a piece of blue masking tape). If the fence is to wide on out feed the cut will not be parreel, to tight and you will hear the saw blade zing as the piece clears. It will take a little time to set it up, but the cuts are worth it.
Steve Pack is offline
post #15 of 15 (permalink) Old 10-07-2020, 11:27 PM
Bob Adams's Avatar
First Name: Bob
I prefer to set my fence parallel to the blade. Using a riving knife and safe cutting practices reduces the chance of kick back. I use a master plate similar to thishttps://www.grizzly.com/products/Gri...er-Plate/G7582 it eliminates any variation there may be between different blades. I use the plate to set up my miter saw as well.
Bob Adams is offline
Table saw safety upgrade MikeMa Shop Safety 24 12-15-2014 05:18 PM
Delta table saw miter guage Pops1 Tools and Woodworking 38 12-10-2012 11:42 AM
Cutting parallel horizontal slots to duplicate this molding. mike72903 Jigs and Fixtures 14 05-31-2012 09:49 PM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Table Saw Miter Guage Fence dunmovn Tools and Woodworking 3 12-11-2006 02:21 PM
