Will a speed control work - Page 2 - Router Forums
 13Likes
post #11 of 17 (permalink) Old 03-04-2019, 08:26 AM
First Name: rob
Originally Posted by mjadams61 View Post
Build you one you can use. here is a motor or find something similiar.
https://www.grainger.com/category/mo...&filters=attrs
Reduced to 20% speed is still 4000 rpm, faster than an induction motor that will be 1800 or 3600 rpm and it is only a 1/4'' shaft.
Rob
tooler2 is offline
post #12 of 17 (permalink) Old 03-04-2019, 11:09 AM
MEBCWD's Avatar
do you have a lathe that you could use?
MEBCWD is offline
post #13 of 17 (permalink) Old 03-04-2019, 11:33 AM
MikeMa's Avatar
First off, I would NOT recommend trying this.....
That said, a guy I knew had a combination mill/metal lathe that had mechanical, but limited, speed control, with an induction motor. He put one of the router speed controls that you can get cheap at Harbor Freight. He makes sure it is set a full speed, turns the machine on, and proceeds to slow the motor with it. I was amazed he did that with out smoking the motor!
So, while it TECHNICALLY worked, he is very likely adding a LOT of extra heat to the motor's windings. I can't imagine that will continue to work as a long term solution for him, and if I were to guess, he will end up with a bad motor of continued use with it. Not to mention the drastic decrease in working power of the machine.
So again, I would NOT recommending putting a speed control on a universal motor, as you risk permanently destroying it.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #14 of 17 (permalink) Old 03-04-2019, 12:27 PM Thread Starter
Not the answer I was hoping for, but THANKS to all anyway.
Potowner1 is offline
post #15 of 17 (permalink) Old 03-07-2019, 01:23 AM
First Name: Mal
The start circuit in an induction motor is normally engaged any time that the motor speed is below about 80% of it's plated speed. The speed of the motor is primarily a function of the supply frequency, with the motor load having a slight second order effect. Increasing or decreasing the voltage applied only affects the current drawn, lower voltage means higher current needed to produce the same power, means more heat produced in motor windings, leading to baking the insulation. That's why a lot of moderate to high power tools come with recommendations about not using them with long (or any) extension cords. The voltage drop in the cord an be underestimated by the lay person, which results in a low supply voltage to the motor, excess current draw through the cable, increased voltage drop in the cable, in an every repeating cycle until a breaker trips, cables fail, or the motor bakes.
malb is offline
post #16 of 17 (permalink) Old 03-07-2019, 03:00 PM
A hand drill is a universal motor so a speed control will work with them. How about building a frame to hold one of them so that you can run it hands free?
post #17 of 17 (permalink) Old 04-03-2019, 10:11 PM
mjadams61's Avatar
First Name: Marlin
Originally Posted by chessnut2 View Post
Thanks for this, Marlin. I've been wondering if something like this was available.
Your Welcome
mjadams61 is offline
Router bit speed control KCount Table-mounted Routing 5 04-05-2018 06:59 PM
Makita Speed Control Issues jtm0100 New Member Introductions 2 06-11-2012 07:51 AM
variable speed control smart alex Table-mounted Routing 9 06-03-2012 11:36 PM
speed control jwnichols General Routing 6 01-22-2010 02:13 AM
"What is it?" #138 reible What is it? 13 10-26-2009 09:07 AM
