Help with Stuck Router Collet - Page 2 - Router Forums
 17Likes
post #11 of 17 (permalink) Old 03-09-2019, 04:38 PM
Nickp's Avatar
First Name: Nick
"For every action there is an equal and opposite reaction"... Thank you, Dr. Newton for your third law...
Put the router on its side...take that drift punch and put it down the middle to the router shaft...lightly tap on it. The slight movement of the punch against the router will eventually loosen the collet and it will pop out... Try this first before tapping on the collet... The fatter the head of the drift punch, the better...If you have brass, even better...
Allow yourself a TINY BIT, less than a drop, of a good lubricant...PB Blaster, Liquid Wrench...let it sit for a while, then the light taps...
...sort of like tapping on the back of a hammer handle to drive the head onto the handle...
LIGHT TAPS, please...
roxanne562001 likes this.
Nick
Nickp is offline
post #12 of 17 (permalink) Old 03-10-2019, 11:03 AM Thread Starter
First Name: Steve
Thanks to all for your wonderful advice and wisdom. I approached the problem with renewed resolve this morning and succeeded in freeing the collet. I warmed up the armature by running the router for about five minutes, sprayed a couple of drops of Boshield into the collet, tightened a hose clamp around the collet which shrank the collet, and pulled it out with a vise gripe. It came out pretty easily. I was also able to snap the collet back into the nut. However, the collet still won't accept half-inch shanks. It's possible that the collet is now misshapen. I will call Triton tomorrow to see if they'll send me a new collet.
Thanks again for the help.
Steve in VA is offline
post #13 of 17 (permalink) Old 03-10-2019, 12:14 PM
If you can't get a bit in it the most likely problem is that the slots in the collet have squeezed together. It shouldn't be distorted unless you did that with the vice grips.
post #14 of 17 (permalink) Old 03-10-2019, 02:39 PM
Collets are amazingly precise bits of engineering. Less than a mm can prevent it from working properly. On half inch collets I drop in a half inch grommet to prevent the bit from bottoming out. For a quarter inch, you could use a "space ball" to do the same. The only collet I've had stick was before I learned the grommet trick. I keep a spare collets around for both brands and sizes of routers, just in case.
post #15 of 17 (permalink) Old 03-10-2019, 05:34 PM
Collets are fairly cheap. Just get a new one.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #16 of 17 (permalink) Old 03-13-2019, 07:55 PM
sreilly's Avatar
First Name: Steve
Steve, it sounds like you got the pros advice so I'll just add a welcome to the forum for good measure. You'll find plenty of help and advice from great people here. BTW, I'm in Virginia as well.
sreilly is offline
post #17 of 17 (permalink) Old 03-14-2019, 12:29 PM
Straightlines's Avatar
First Name: Bradley
Steve, I’m an avid user of Boeshield and point out that it is a paraffinic lubricant which therefore hardens after the carrier solvents have evaporated. Hardened paraffin deep inside your collet probably isn’t a good thing, so I suggest you use a light oil, or Slick-50, or maybe a dry Teflon type lube instead.
graeme.c.payne likes this.
Straightlines is offline
Router Bit Depth Setting In Collet Gaia Table-mounted Routing 18 12-06-2018 06:40 PM
Collet Nut Stuck ekeogh General Routing 20 06-27-2018 07:53 PM
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
