Dewalt 735 planer - Is there another planer to consider at this price point? - Page 2 - Router Forums
 85Likes
post #11 of 52 (permalink) Old 03-12-2019, 05:20 PM
JFPNCM's Avatar
First Name: Jon
I am very pleased with my 735 and based on those results my neighbor invested in one as well. Same comments from his side. Excellent choice. I added a drawer into the stand as well.
The key will be dust collection. Don't try connecting it to a standard shop vac and if you use a cyclone chip collector make certain the lid is fastened tight.
Enjoy.
sgcz75b likes this.
Jon
JFPNCM is offline
post #12 of 52 (permalink) Old 03-12-2019, 05:40 PM
TwoSkies57's Avatar
For the money, you MIGHT and its a mighty big MIGHT, find a better unit for sale used somewhere. But my experience has been that they just come up very often at all. I look all the time at equipment.
I've had my 735 for 4 or 5 yrs now and I've never looked back or had a regret.
sgcz75b likes this.
Skipper the Penguin
TwoSkies57 is offline
post #13 of 52 (permalink) Old 03-13-2019, 08:06 AM
sreilly's Avatar
First Name: Steve
The big difference between that and a floor standing model is depth of cut. The King I have which is sold under many other names including I think Jet will take a 1/8" cut per pass. It's bigger and more robust with more power. Mine runs on 220. I've run 20' rough lumber through it and one of the reasons I wanted it is I have access to lots of rough lumber here which would wind up working a small planer too hard. I'd love to upgrade to a Byrd spiral segmented head but it's worth as much as the rest of the planer. It might still be an option for you but the reviews are pretty good with straight knives too. I get some pretty bad tearout with the white birch I run through mine.
Chuck I had thought of getting a spiral head for the jointer and have to say I thought long and hard only to realize that that cut was far from the finished surface so why spend so much on a surface that will still be worked? If cost were no issue I'd say go for it but you will be sanding and for really figured grain you may also be hand planing which if done properly will leave you with the best surface. I guess it depends on how much time you have and how much work to do. But you'll also likely be sanding if not using a hand plane. At least that's the direction I'm headed at this point but that doesn't mean it's for everyone. I really just want my planner to dimension the thickness and be flat. If I run the board on the jointer first properly and get a flat surface then a 90 degree edge I'm golden. Plane to thickness and continue the project. A few passes with a well tuned jack or smoothing plane will leave surface that's velvety smooth and ready for a finish. At least that the theory I'm working with for now. I could be way off here of course as I haven't gotten the planes yet ready for work.
artman60 and sgcz75b like this.
sreilly is offline
post #14 of 52 (permalink) Old 03-13-2019, 08:09 AM
sreilly's Avatar
First Name: Steve
All posts and comparisons I've seen have the 735 at the top of the list. I have several friends that use them and are very happy without having issues.
sgcz75b likes this.
sreilly is offline
post #15 of 52 (permalink) Old 03-13-2019, 08:42 AM
First Name: JJ
The WEN 6552T 13 in. 15 Amp 3-Blade Benchtop so far has been a good machine. The cuts have been smooth. Glad I went with it and saved a bunch of money in the process.
Flipsaw is offline
post #16 of 52 (permalink) Old 03-13-2019, 09:21 AM
difalkner's Avatar
First Name: David
Enjoy.
And I'll add to that, Jon - turn your DC on first and then start the planer. If your hoses aren't fastened with clamps and your bag has any weak spots or leaking seams or loose lid then the blower on the 735 will knock the hoses off and show you any weak spots in your DC system... not in a good way!
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is offline
post #17 of 52 (permalink) Old 03-13-2019, 09:37 AM
chuckgray's Avatar
First Name: Chuck
Originally Posted by sgcz75b View Post
I wish I could find an 8" jointer this good and at this price point.
Hello Steve, I purchased the Cutech 8" jointer with carbide inserts several years ago and have jointed a couple hundred feet of maple, walnut and cherry and I'm totally satisfied with its performance. It doesn't have a long bed on it, but I haven't had any issues jointing 4' lengths and that's without using the bed extenders.
https://www.cutechtool.com/product-p/40180hc-ct.htm
PS: they now offer Teflon coated tables for an extra $20. If this option was available when I made my purchase, I probably would have gotten it.
chuckgray is offline
post #18 of 52 (permalink) Old 03-13-2019, 10:16 AM Thread Starter
sgcz75b's Avatar
First Name: Steve
David
I'm adding a 4"45-degree elbow off the planer port for two reasons.
1. to slightly slow down the velocity of the chips before adding the hose from the dc.
2. to angle the hose down and away from the outfeed table.
I'll use this cuff to attach to the planer port before adding the elbow. I can recommend these Powertech cuffs as very strong and secure.
Steve
artman60 likes this.
"What can be asserted without proof can be dismissed without proof." Christopher Hitchens
sgcz75b is offline
post #19 of 52 (permalink) Old 03-13-2019, 10:36 AM
Steve the spiral cutters might still require sanding out imperfections but it's easier to sand those out than it is to sand tear out smooth. Any type cutter heads require some sanding anyway to get rid of chatter marks.
post #20 of 52 (permalink) Old 03-13-2019, 10:38 AM
Steve
Keep an eye on that for the first little while Steve. Sharp 90s can plug much more easily and those machines can pack the sawdust in pretty tight if they do get plugged. VOE there. I wound up removing the chute on my big planer.
JFPNCM, jj777746 and artman60 like this.
Sold: Grizzly 6" jointer, Dewalt 735 w/Byrd head - Atlanta area billg71 Woodworking Classifieds 8 04-20-2014 09:09 AM
Retail Price for Consignments Dejure Lobby 9 01-20-2014 06:39 PM
Dewalt DW735 planer carbide knives Jack Wilson Tools and Woodworking 7 10-07-2013 08:16 PM
Thinking Of Upgrading Planer Jerry Bowen Tools and Woodworking 23 06-14-2013 06:01 PM
got a brand new DEWALT 735 planner today at HD for $379 tryingtokeepmyfingers Lobby 5 07-25-2009 08:31 PM
