Made Router Trammel From Harry's Router Ski - Router Forums
 21Likes
  • 9 Post By JIMMIEM
  • 7 Post By harrysin
  • 1 Post By RainMan 2.0
  • 1 Post By JIMMIEM
  • 2 Post By harrysin
  • 1 Post By JIMMIEM
post #1 of 6 (permalink) Old 03-16-2019, 06:17 PM Thread Starter
Contributor of the Month
Default Made Router Trammel From Harry's Router Ski
I needed a router trammel for a current project. I had made some router skiis using Harry's plans. I attached a wood block to a router ski and drilled a hole in the block for the pivot pin. I used threaded rods for my skiis which made it easy to adjust the trammel to exact length. Because of the rod slots in the ski the router base thickness is infinitely adjustable. Took me a couple of minutes to attach the wood block. Worked perfectly. Thank You again, Harry.
kp91, harrysin, papasombre and 6 others like this.
JIMMIEM is offline
post #2 of 6 (permalink) Old 03-17-2019, 09:08 AM
harrysin's Avatar
First Name: Harry
No thanks necessary Jim BUT, where are the pictures, everyone knows that I like pictures, besides, a picture really is worth a thousand words.
Harry
harrysin is online now
post #3 of 6 (permalink) Old 03-17-2019, 09:09 AM
RainMan 2.0's Avatar
For some reason the pictures are not showing
RÖENTGEEP likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 6 (permalink) Old 03-20-2019, 05:51 PM Thread Starter
Here are the pictures. I used the ski prototype for the trammel. The finished skiis wanted to be in the picture too. I used the trammel to route the slot in the auxilliary drill press table. The slot allows the fence to pivot.....got the plans from WoodSmith magazine. I searched for trammel plans. I saw one that used a block of wood for the pivot. The block was drilled to accept the rods. With the router skii I already had the pivot....just needed to add a piece of wood for the pivot pin.
jj777746 likes this.
JIMMIEM is offline
post #5 of 6 (permalink) Old 03-21-2019, 07:35 AM
harrysin's Avatar
First Name: Harry
Jim, that really is thinking outside the box, even I had never thought of such a modification. I'm going to have to watch you closely or you're likely to take over from ME!!
Exceptionally well made, my only other comment is that bright mild steel is more elegant than allthread. (I couldn't give you 10/10 on principle)
JIMMIEM and papasombre like this.
Harry
post #6 of 6 (permalink) Old 03-21-2019, 07:55 AM Thread Starter
Hi Harry,
Don't worry I couldn't come close to your skill level.
I had watched how you had done the bright mild steel but I don't have the tools to do that so I settled for the threaded rod. As I continued to think about it, being able to adjust the rods up or down in the ski slots would allow the trammel point and router to operate on different planes. Routing that curved slot on my auxiliary drill press table was very easy to do.
harrysin likes this.
JIMMIEM is offline
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
overcomming home made router table snags matey Table-mounted Routing 5 01-27-2011 07:36 PM
