question about JET 10-20 Drum Sander - Page 2 - Router Forums
 17Likes
post #11 of 17 (permalink) Old 04-08-2019, 06:38 AM Thread Starter
kywoodchopper's Avatar
First Name: malcolm
Anything to help in getting this paper installed in the 10-20 Jet drum sander.
Last edited by difalkner; 04-08-2019 at 07:01 AM. Reason: removed personal contact info
kywoodchopper is offline
post #12 of 17 (permalink) Old 04-08-2019, 07:50 AM
Malcolm I can't offer you any advice but I was thinking about buying one and this thread has given me reason to rethink that possibility. So then the question becomes is there a comparable drum sander which has an easier means of changing belts?
Herb Stoops likes this.
billyjim is offline
post #13 of 17 (permalink) Old 04-08-2019, 08:13 AM
Forum Moderator
difalkner's Avatar
First Name: David
Take a look at SuperMax.
David
JFPNCM and Herb Stoops like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #14 of 17 (permalink) Old 04-08-2019, 07:54 PM
David's tip is go0od. I bought the Supermax 16/32 to replace my Performax 16/ 32 because i won a gift certificate for $500. and sold my old one for $500. At that time they ran $1100. + shipping. The Performax was $1400. + shipping. The new this year 16/32 SuperMax has way more freatures than the Performax. If I couldn't get a SuperMax, I would buy a Jet,which is the improved Performax. They extended the shaft out on the Jet so there is more room from the motor to the end of the drum on the right side which is easier to get to the RH clip. You can't go wrong with either, I Use my drum sander as much as my table saw. I would not have a shop W/O one, and I can change belts in less than 3 min. everytime.
JFPNCM and difalkner like this.
Herb Stoops is offline
post #15 of 17 (permalink) Old 04-09-2019, 11:28 AM
JFPNCM's Avatar
First Name: Jon
I second the comments from David and Herb. I have the Supermax 16/32 and couldn’t be happier. Prior to the purchase I used my neighbors old (pre Jet) Supermax and the updates are superb.
Jon
JFPNCM is offline
post #16 of 17 (permalink) Old 04-09-2019, 11:20 PM
gdonham1's Avatar
First Name: Guy
I have a Jet 16-32 and paper changes can be challenging. The side against the motor is always the worst. The tool is hard to use but is the only way to go. You hook it in the hole of the spring loaded finger and flip the tool up on top of the drum. That holds the finger open. Wrap your paper keeping it tight and if possible reach down and get hold of the end of the paper after it is inserted in the slot where the spring loaded finger is. Hold the paper tight and move the Tuff Tool back over the side of the drum and that lets the spring loaded finger grab the end of the paper. Sometimes it is easier to do the side next to the motor first and wrap the paper around and attach on the open side last. That sounds backward but what ever works works.
The paper must be tight on the drum or it makes noise (a slapping sound), gets wrapped over it self and burns your work and ruins the paper. When running your work through the machine keep alternating from side to side and down the middle. This gives you even wear on the paper and makes the paper last longer. Also get one of the gum type sand paper cleaning sticks and clean the paper periodically to keep it from loading up. You must always use dust collection or the paper wont last till the water gets hot and will smoke you out of your shop and fill your lungs with fine dust.
Also important is that you have the right amount of the tail of the paper in the spring loaded slot. Too wide and the paper will not hold, too little and it slips out. You should have about the same amount of the tapered end through both slots the same amount. This is trail and error method but after you get it right a few times it will be simplier.
gdonham1 is offline
post #17 of 17 (permalink) Old 08-22-2020, 03:05 PM
Originally Posted by kywoodchopper View Post
I know this isn't about routers, but I have a Jet 10-20 drum sander. I am trying to replace the sandpaper for the first time.
After 4-hours working at it, I haven't accomplished anything. Do any of you know of anyone that has actually replaced the paper in the 10-20 sander?
I checked Youtube, but they discuss a different model whose top opens. Then a foreign video shows replacing the paper with the drum out.
H E L P!
I contacted JET, but so far no response. The clip on the right side is impossible to get your fingers on it and the paper is trying to go in the wrong direction.
This sent a device for assisting, but it is totally useless.
The only way to wrap sandpaper on this POS is to remove the drum, then use locking needle nose pliers to pull the end tight.
Whoever designed this thing obviously had their head up their butt. (Also the pitiful tracking adjusters, and 9 amp breaker.)
Just try running a shop vac at the same time as this thing - shuts off constantly.
SAVE YOUR MONEY, AND HOURS OF CONSTANT FRUSTRATION.
Tele 1941 is offline
Drum sander recommendation JFPNCM Tool Reviews 20 10-24-2017 12:10 AM
Jet Vortex dust collector technical question? skiroy56 Tools and Woodworking 9 08-26-2012 05:58 AM
jet model 22-44 oscillating sander R B Battleford Tools and Woodworking 2 05-19-2010 09:24 AM
Drum sander Xmas tree ornament plans? Nickbee Project Plans and How To 0 12-13-2009 11:29 AM
sanding belts for a grizzly drum sander 27 judge Tools and Woodworking 1 12-12-2009 08:37 AM
