Should you use glue with pocket holes - Page 2 - Router Forums
 25Likes
post #11 of 11 (permalink) Old 04-11-2019, 10:20 AM
My favorite use is for face frames. Turns out that what makes the frame square is the acuracy of the 90 degree cuts. I spend some time making sure the sawblade is exactly 90 to the table and use a very acurate sled to make cuts. The screws then pull the frame into the perfect alignment. Someone posted about pre gluing the end cuts, letting it dry, then reapplying glue for the final glue up. I now do that on face frames. For awhile I also trimmed the ends with my Griz miter trimmer, which gave a perfect, almost glass smooth surface. I found that wasn't necessary and just use a good Freud industrial rip blade that gives a glue ready cut.
Herb Stoops and artman60 like this.
Drilling Shelf Pin Holes without a jig and without measuring Cherryville Chuck Project Plans and How To 14 11-23-2016 05:06 PM
Using router for glue up Mickeyt Table-mounted Routing 26 01-18-2016 10:21 AM
Cutting small holes lilcee Wood Scrolling 3 07-14-2012 07:26 AM
Which holes do I use to attach freud ft2200 to mounting plate? Jmacdona Table-mounted Routing 7 05-22-2012 11:46 PM
