Forstner bit question - Page 2 - Router Forums
 22Likes
post #11 of 21 (permalink) Old 04-23-2019, 11:06 AM Thread Starter
fmakrancy's Avatar
Default Thanks to all that replied :)
Welp. Common sense got me this time. What I failed to mention was that I made a new vacuum jig from scrap wood to keep the shavings at bay and from going all over the place for this particular application. I disassembled it yesterday and wouldn't you know there is a hole bored right through the jig directly under where I am boring out the new wood. I am going to replace it this evening and I expect this problem will just go away. I guess I'll file this one under D for DUUUUUUUUUUUH!!!!
DesertRatTom and tulowd like this.
fmakrancy is offline
post #12 of 21 (permalink) Old 04-23-2019, 11:54 AM
I'd still use a backer board, and I'd clamp the target piece and backer down securely so they behave as one solid piece
fmakrancy likes this.
post #13 of 21 (permalink) Old 04-24-2019, 05:39 PM
First Name: Orlando
that's a compression mark..
your bit is dull and you are excreting more pressure to bore than you would w/ a sharp bit..
and stop using a bit w/ teeth...
use this style instead...
Stick, who makes that bit?
OBG65 is offline
post #14 of 21 (permalink) Old 04-24-2019, 06:18 PM
CMT
Freud
Irwin
Colt
Famag
Bormax
Bosch
Vermont American
DWT
LeeValley
post #15 of 21 (permalink) Old 04-24-2019, 07:37 PM
First Name: Orlando
Thanks Stick. Looked at some of those brands and most are scalloped. Only one without any scallops or are saw toothed are the W. L. Fuller series 909 and 060. The 909 series has a center point while the 060 don't since according to Fuller it's guided by its circular rim. But the 060 are $60+ each.
OBG65 is offline
post #16 of 21 (permalink) Old 04-24-2019, 07:46 PM
try this...
https://duckduckgo.com/?q=forstner+d...&t=ffsb&ia=web
post #17 of 21 (permalink) Old 04-24-2019, 07:48 PM
BTW...
W.L. Fuller is a squared away company...
post #18 of 21 (permalink) Old 04-25-2019, 06:10 PM
First Name: Orlando
BTW...
You are right on that Stick. Top notch stuff. I have their tapered bits, brad point, and plexipoint bits, Type B CB, Type C & H CS, collars, drill bushings, & stops. I have some PC forsteners that I may change out incrementally to the Fullers as need arise since I have had great success with Fuller products. But the Bosch and Diablo/Freud look good also.
OBG65 is offline
post #19 of 21 (permalink) Old 04-25-2019, 06:29 PM
You are right on that Stick. Top notch stuff. I have their tapered bits, brad point, and plexipoint bits, Type B CB, Type C & H CS, collars, drill bushings, & stops. I have some PC forstners that I may change out incrementally to the Fullers as need arise since I have had great success with Fuller products. But the Bosch and Diablo/Freud look good also.
I've been very pleased w/ the Bosch and Freuds... more so w/ the Freud...
the German made Colts, Bormaxs and Famags are a tough act to follow...
post #20 of 21 (permalink) Old 04-25-2019, 06:38 PM
First Name: Orlando
Who is your source for the German made ones?
OBG65 is offline
Eagle America Keepsake Box Router Bit gdonham1 Router Bits - Types and Usage 1 11-20-2018 10:06 AM
1/8 Shank bit question JoeRalat Router Bits - Types and Usage 9 07-15-2015 08:45 AM
Question about rabbeting bit sets LBrandt Router Bits - Types and Usage 2 07-19-2009 05:07 PM
Bit for jointing question dabeeler Router Bits - Types and Usage 11 11-13-2007 10:57 AM
