Drum sander snipe solution - Router Forums
 15Likes
  • 9 Post By difalkner
  • 1 Post By twmv86
  • 1 Post By Nickp
  • 4 Post By hawkeye10
post #1 of 4 (permalink) Old 04-21-2019, 09:51 PM Thread Starter
difalkner's Avatar
First Name: David
Default Drum sander snipe solution
For those of you who use a drum sander you know that sometimes you'll get snipe just like on a planer. The trick to eliminating that is just like with a planer - use a sacrificial board in front of and behind the work piece.
Now, that's all fine and dandy if you have straight edges on your work piece but if it's oddly shaped or round, then what do you do? Well, what I do is save the cut-offs from the work piece. They're the same thickness and should fit pretty closely to run in front of and behind the target work piece.
A few weeks ago I cut a large Lazy Susan and didn't allow enough on my scrap pieces to use them on the drum sander. What I ended up with was a very beautiful Walnut Lazy Susan but at the correct angle, and if you knew what to look for, you could see some very faint snipe. I didn't take a photo but I could see it.
So when I made this even thicker Walnut cutting board I was determined to not fall into that trap. My cut-offs were large enough to go in front of and behind the cutting board and what I ended up with is a perfectly flat 18" round surface. I cut the scrap pieces down to where they fit just inside the width of our 19/38 drum sander and made sure to feed them in before and after the cutting board on each pass of each grit from 120/150/220.
Drum sander snipe solution-007-18-inch-round-walnut-2-inch-thick-cutting-board.jpg
I've also done this with angled pieces where the leading edge is angled relative to the grain direction and it truly makes a difference.
David
kp91, JFPNCM, Wildwood and 6 others like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #2 of 4 (permalink) Old 04-21-2019, 10:38 PM
First Name: n/a
thats just plain beautiful
difalkner likes this.
twmv86 is offline
post #3 of 4 (permalink) Old 04-23-2019, 09:15 AM
Nickp's Avatar
First Name: Nick
Nice fix...good use of the cutoffs...kill two birds with one stone...thanks for sharing...
Nick
Nickp is online now
post #4 of 4 (permalink) Old 04-23-2019, 10:34 AM
hawkeye10's Avatar
First Name: Don
David, that is a beautiful cutting board. One of the best I have seen. When I grow up I want to be a master woodworker like you.
Don in Murfreesboro,Tn.
hawkeye10 is offline
question about JET 10-20 Drum Sander kywoodchopper Tools and Woodworking 16 08-22-2020 03:05 PM
Does anyone use a Double drum sander RainMan 2.0 Tools and Woodworking 13 08-17-2014 03:19 PM
question about V Drum Sander size Tom in indy Tools and Woodworking 3 03-09-2014 04:15 PM
Build Mobile base for a drum sander RickPr Tools and Woodworking 10 01-12-2013 09:15 AM
DS-1632 Drum Sander, Any Good. wm460 Tools and Woodworking 10 03-03-2012 03:28 AM
