Good Advice from Dr T - Router Forums
 36Likes
  • 3 Post By honesttjohn
  • 3 Post By DesertRatTom
  • 7 Post By kp91
  • 4 Post By vchiarelli
  • 3 Post By RainMan 2.0
  • 4 Post By difalkner
  • 5 Post By Herb Stoops
  • 2 Post By DesertRatTom
  • 2 Post By kp91
  • 3 Post By ger21
post #1 of 10 (permalink) Old 04-22-2019, 04:20 PM Thread Starter
Default Good Advice from Dr T
Finally got my Wixey Angle Gauge after Amazon lost the first one. Table saw was almost a degree off. Looks like it will be used regularly.
Thanx for the suggestion Dr T.
difalkner, TenGees and RainMan 2.0 like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #2 of 10 (permalink) Old 04-22-2019, 04:40 PM
You bet John. I check blade angle all the time, even if I've not changed what blade position for awhile. Discovered the Wixey early on when I found I couldn't glue something up because of a small blade angle error. The markings on the saw are completely unreliable. And the new ones have a regular AAA battery and rear illumination--for us old-eyes folks.
kp91, jj777746 and honesttjohn like this.
post #3 of 10 (permalink) Old 04-22-2019, 04:46 PM
kp91's Avatar
First Name: Doug
The one thing I HATE about my original Wixey gages is I have to take the coin batteries out all the time they aren't in use. They are always dead the moment I need them most!
The AAA battery upgrade was a great idea
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 10 (permalink) Old 04-22-2019, 04:55 PM
vchiarelli's Avatar
First Name: Vince
I'm with you Doug - I've had my Wixey for years and I hate the coin batteries - I've got them in other devices in my shop too. And they're always dead. When I was in the US recently I purchased a sleeve of the batteries at Harbor Freight and couldn't believe how little they cost.
kp91, jw2170, Herb Stoops and 1 others like this.
vchiarelli is offline
post #5 of 10 (permalink) Old 04-22-2019, 07:05 PM
RainMan 2.0's Avatar
Yes this is disappointing . I bought mine and never installed it, and next thing you know the aaa comes out right after I purchased mine .
kp91, DesertRatTom and Herb Stoops like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 10 (permalink) Old 04-22-2019, 07:31 PM
difalkner's Avatar
First Name: David
It's a good tool in the shop and I use mine on the table saw all the time. I have hard stops at 90° and 45° on the table saw blade but I check it anyway with the Wixey gauge.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 10 (permalink) Old 04-22-2019, 10:28 PM
I never use mine any more because the batteries are always dead. Same for the digital calipers I finally got the one with the dial and no battery. I have some on machines for depth and they are always dead too ,except the ones that have on/off switches on them.
Go Harbor Freight!!!. I will have to run down there and check them out.
kp91, jw2170, DesertRatTom and 2 others like this.
Herb Stoops is online now
post #8 of 10 (permalink) Old 04-23-2019, 12:28 PM
Off to Harbor freight, thanks. For those with the old Wixey, pop for the new one, just $30 and it lights up and is easier to read. I always turned my old one off after use, so the battery was OK. But the button batteries are always dead when I want to use the calipers and other devices. I finally got a dial caliper (used at pawn shop) for a couple of bucks, with a nice case, USA made too.
I just don't buy anything that uses button batteries, except for my hearing aids.
BTW, for hearing aids, check out Cosco. Less than half the cost of the same aids from a private dealer, and they have the best hearing test gear around, and adequately trained audiologists. I mentioned getting fitted ear pieces and they gave me oversized transducers (tiny speakers) and a short connector to the aid. Bad choices. Now have longer "wire" and little ear retainers that hold the aid in the ear canal. I mention this because many of us geezers can't hear worth a damn, and even the cheapest of the Costco aids ($1400 a pair) will get you back engaged in life.
kp91 and Herb Stoops like this.
post #9 of 10 (permalink) Old 04-23-2019, 02:16 PM
kp91's Avatar
First Name: Doug
It's amazing what the new hearing aids can do! My oldest has behind the ear versions, they can use either the rechargeable battery or the button cells. They are Bluetooth compatible with her phone, and have a remote microphone that she can have her professor wear or keep on the desk, and it also plugs into a headphone jack if she has to listen to something on a computer. They can be tuned and adjusted by the audiologist as needed almost instantly.
They have really helped.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #10 of 10 (permalink) Old 04-23-2019, 06:24 PM
ger21's Avatar
First Name: Gerry
There's no substitute for a good, small square to check the cuts coming off the table saw.
kp91, jw2170 and DesertRatTom like this.
Ger
www.cncwoodworker.com
ger21 is offline
BOSCH 1617EVS mounting on a router table ironman21 Table-mounted Routing 59 10-31-2018 05:15 PM
First box joints Debbie Show N' Tell 39 04-10-2018 06:35 PM
New comer to forum ironman21 New Member Introductions 24 03-09-2018 12:27 AM
Are 1/4" routers ok? Learningtorpute General Routing 26 05-30-2016 10:48 AM
Advice on a good lettering template Bluntmode Guide Bushings and Templates 1 06-07-2011 04:38 PM
