Hot Glue Gun Recommendation...? - Page 2 - Router Forums
 34Likes
post #11 of 39 (permalink) Old 05-04-2019, 01:22 AM
MEBCWD's Avatar
Stick you missed plug-in or battery powered
MEBCWD is offline
post #12 of 39 (permalink) Old 05-04-2019, 01:37 AM
no I didn't...
post #13 of 39 (permalink) Old 05-04-2019, 05:58 AM
TwoSkies57's Avatar
I've had a Craftsman glue gun for don't know how long. Cost was probably around 20 bucks when I bought it. Nice thing about it, is that it came with a stand and the power cord can be disconnected when in use. You do have to plug it back in after the gun begins to cool down or just leaveit plugged in!!
With the addition of grand kids to the clan, it see's more use than ever, repairing dolls, cars, shoes and all manner of toys . Works very well in most applications.
Couple of down sides. Application nozzle usually over applies the glue. Glue typically turns yellow in time. Neither of which are a big deal considering what I use the stuff
for.
Its all about the glue sticks that you use!!!!!! Usually a couple minutes to heat up and then to cool down. All in all, not a bad addition to any shop.
Nickp and Herb Stoops like this.
Skipper the Penguin
TwoSkies57 is offline
post #14 of 39 (permalink) Old 05-04-2019, 07:30 AM Thread Starter
Nickp's Avatar
First Name: Nick
I use mine occasionally when I need a quick bond that can be taken apart later or to hold something while a better glue hardens. For example when I make extra table saw inserts I hot glue the factory one to some mdf and use a pattern bit to route it to size. Same goes for quick and easy jigs. Hot glue them together and if you need extra hold add regular glue or brads or both. Get one and use it for a few things like that and youíll probably start seeing other possibilities.
..."build it, they will come"...
I think that's where it might wind up. Since I've never had one, I might find other uses other than small repairs. I like the idea of temporary use you mentioned. I might wind up with a mini for small jobs...
Thanks....
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
post #15 of 39 (permalink) Old 05-04-2019, 07:36 AM
TwoSkies57's Avatar
Nick...
alot of good general information over at hotmelt:
https://www.hotmelt.com/
Herb Stoops likes this.
Skipper the Penguin
post #16 of 39 (permalink) Old 05-04-2019, 07:49 AM Thread Starter
Nickp's Avatar
First Name: Nick
for.
Thanks, Bill...good to hear...
I'm likely to see the same in using it. The important thing I see is picking the right one so that it works efficiently. This way I won't have a bad gun giving me results that will make me just want to throw it out...
I appreciate the feedback...
Nick
Points to Ponder...
Nickp is offline
post #17 of 39 (permalink) Old 05-04-2019, 08:18 AM
I got just a cheap one - under $10. Main use I've found for it is for gluing shipping package material. Cheaper, stronger and neater than packing tape, but not really cheap overall. My stuff is all different sizes so I buy cardboard separators instead of a lot of boxes and wrap the item(s) accordingly. Have had comments on how "good" my packaging is. Don't use it much for other stuff, but when needed it comes in pretty handy.
The big cost is the glue sticks. I buy them by the case. They do not last long. Kind of like the cheap razor with expensive blades.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #18 of 39 (permalink) Old 05-04-2019, 09:33 AM
Gaffboat's Avatar
First Name: Oliver
I have one from Amazon that has worked very well. It has two temperature settings, heats quickly, doesn't drip, and the long nozzle makes it easy to get into tight areas. Best of all, it's only $25.
https://www.amazon.com/Nozzle-Premiu...gateway&sr=8-1
Gaffboat is offline
post #19 of 39 (permalink) Old 05-04-2019, 09:44 AM
roxanne562001's Avatar
First Name: Roxanne
I have several under 20 bucks I use them for many different crafts what ever you get make sure it uses standard glue sticks. I bought one a while back it used a weird size and couldn't readily find sticks for it.
roxanne562001 is offline
post #20 of 39 (permalink) Old 05-04-2019, 09:44 AM Thread Starter
Nickp's Avatar
First Name: Nick
Thanks, Oliver...I did see this on Amazon...
Do you find it will stand on it's own okay...? Or does it want to lay over...
The tip is what interested me most...
Nick
Points to Ponder...
Nickp is offline
Thanks to Frank for this one harrysin Lobby 12 07-28-2017 05:32 AM
Hot glue? hawkeye10 Tools and Woodworking 9 11-13-2015 08:46 PM
Hide Glue Daikusan Tools and Woodworking 9 02-11-2014 06:47 AM
