Hot Glue Gun Recommendation...? - Page 3 - Router Forums
 34Likes
post #21 of 39 (permalink) Old 05-04-2019, 09:51 AM Thread Starter
Nickp's Avatar
First Name: Nick
Another question...
I noticed that most guns might have 1/2 stick of glue when the back end of the stick enters the barrel...
If you wanted to change glue type, how do you get the old stick out to insert a new different glue stick...? Or do you just waste the original stick and squeeze it out...?
Does the point come off and push it out backwards...?
Just thinkin' ahead...
Nick
Nickp is offline
post #22 of 39 (permalink) Old 05-04-2019, 12:11 PM
Not sure about getting one out like that. Colour indicates both holding power and required temperature range. The darker the yellow the hotter temperature to melt it/ faster it hardens and the better it holds. The white/ clear ones have the weakest bond at the lowest temp.
post #23 of 39 (permalink) Old 05-04-2019, 04:34 PM
kp91's Avatar
First Name: Doug
Glue another stick to it, then you can pull it right out.
I have a single temp gun, I have never needed to use low melt temp guns. My wife has a little low melt gun from the craft store that uses the smaller diameter sticks, about the only thing I could see needing that for is gluing wires down on a circuit board.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #24 of 39 (permalink) Old 05-04-2019, 04:56 PM
Gene Howe's Avatar
First Name: Gene
Here's the one I got from Anazon. Really handy.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
kp91 likes this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #25 of 39 (permalink) Old 05-04-2019, 05:34 PM
Originally Posted by Nickp View Post
Thanks, Oliver...I did see this on Amazon...
Do you find it will stand on it's own okay...? Or does it want to lay over...
The tip is what interested me most...
Nick you can get long tips separate:
https://www.amazon.com/Assortment-In...AT7T433RR20GH9
https://www.amazon.com/Nozzle-Assort...70S2TCX8FXG1F6
TenGees and Nickp like this.
Herb Stoops is offline
post #26 of 39 (permalink) Old 05-04-2019, 06:18 PM Thread Starter
Nickp's Avatar
First Name: Nick
Originally Posted by Herb Stoops View Post
Now we're talkin' versatility...or as Popeye would say "verskitiliky"...
Thanks, Herb...ya just pushed me over the edge...
Herb Stoops likes this.
Nick
Nickp is offline
post #27 of 39 (permalink) Old 05-04-2019, 09:24 PM
JFPNCM's Avatar
First Name: Jon
Look forward to the continued discussion. In the interim, i’ll Continue to use double sided tape.
Jon
JFPNCM is online now
post #28 of 39 (permalink) Old 05-05-2019, 09:34 AM
Gaffboat's Avatar
First Name: Oliver
Originally Posted by JFPNCM View Post
Look forward to the continued discussion. In the interim, iíll Continue to use double sided tape.
Although I often use double-sided tape, sometimes it wonít work, Jon.
When I was making my Madame Zola Fortune Teller project, I needed to hold the box on the CNC so I could cut a large hole for the mechanism. The box was too tall for any clamps, and the bottom was open, so I screwed cleats along the sides to prevent any lateral movement. As a precaution against the box lifting from the table, I used hot glue where the sides met the cleats. I was able to make the cut with no problems, and remove the glue when I was finished.
JFPNCM, TenGees and Herb Stoops like this.
Gaffboat is offline
post #29 of 39 (permalink) Old 05-05-2019, 10:45 AM Thread Starter
Nickp's Avatar
First Name: Nick
@Gaffboat
Oliver...I couldn't help notice in the picture of the gun that the on/off switch is also the 60/100 selector...
Is it in fact dual temp or how would the switch allow for selecting 100W if it's also the power switch...?
Signed...Confused...
Nick
Nickp is offline
post #30 of 39 (permalink) Old 05-05-2019, 10:57 AM
mimac's Avatar
First Name: Brian
What you need depends on what you intend to use it for. I have two of the regular single heat guns that I use for light duty stuff which is ok for most things. I had a need for something stronger and more permanent so I got one of these :
https://www.gluegun.com/products/tit...r-pur-glue-gun
This thing is expensive and the cartridges are not cheep but it really holds. If you have to take a joint apart one of the pieces will often break. The glue also stands up to exterior applications as well. The gun is made by Steinel and the glue by Titebond.
Here's a review on Lumberjocks
https://www.lumberjocks.com/reviews/9634
mimac is offline
Thanks to Frank for this one harrysin Lobby 12 07-28-2017 05:32 AM
Hot glue? hawkeye10 Tools and Woodworking 9 11-13-2015 08:46 PM
Hide Glue Daikusan Tools and Woodworking 9 02-11-2014 06:47 AM
