Hot Glue Gun Recommendation...? - Page 4 - Router Forums
 34Likes
post #31 of 39 (permalink) Old 05-05-2019, 11:24 AM Thread Starter
Nickp's Avatar
First Name: Nick
Originally Posted by mimac View Post
What you need depends on what you intend to use it for. I have two of the regular single heat guns that I use for light duty stuff which is ok for most things. I had a need for something stronger and more permanent so I got one of these :
https://www.gluegun.com/products/tit...r-pur-glue-gun
This thing is expensive and the cartridges are not cheep but it really holds. If you have to take a joint apart one of the pieces will often break. The glue also stands up to exterior applications as well. The gun is made by Steinel and the glue by Titebond.
Here's a review on Lumberjocks
https://www.lumberjocks.com/reviews/9634
Nice review, Brian...thanks for the link...
Not sure yet if I need anything as strong as the purformer...I'm likely to continue using my traditional joinery techniques but, based on what I've read about this gun, it could change some of that. As I said, I've never owned one so I'm likely to be surprised when I start using one...
Thanks again for your response...Nick
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
post #32 of 39 (permalink) Old 05-07-2019, 10:45 AM
tulowd's Avatar
First Name: Paul
Glue guns.....actually hot melt guns are one of the basics of working on car interiors from my car audio installation days in the 80s and 90s.
Cheap guns and cheap glue works pretty well, especially when it's temporary.
The chemistry and technology that are in the hot melt industry are amazing, no different than the machinery some of us have in our shops - ranges from Black and Decker one time use all the way to industrial grade with a price point 20x higher.
Car manufacturers and their Tier 1 suppliers like Textron used to use hot melt for various dash and trim assembly production. After looking into this for my shop back then, I spent $200 in 1992 to get a 3M entry level hot melt gun. It was a precision instrument that also happened to be indestructible and small, light and convenient to use. Willing to bet money, it still exists and works. Never leaked out the tip, easy flow and control, etc.
The melt sticks and their compounds and melting points are also a huge part of the equation.
I recently looked into replacing my $5 cheapie that's been living in my toolbox for 20 yrs. I ended up with a $20 Arrow gun that is ok, but wont stand up on it's own and is only one temp.
Anything else I found remotely decent was over $100. Since I don't really use it, and have several hundred sticks left, this gun is fine for now. I would prefer a 3M again, but spending money on everything else has made this $20 worthwhile.
NOTE: there are 2 (or possibly more) stick diameters, so make sure you get the correct sized tool for whatever hotmelt you plan on using and being able to replenish. Obviously the general purpose is the least expensive and probably covers most of our uses from cardboard to templates to fabric and wood connections. Real hot melt is very expensive and must be purchased by the case.
Nickp likes this.
a 16 year old hooligan stuck in a 55 year old's carcass
tulowd is offline
post #33 of 39 (permalink) Old 05-07-2019, 04:03 PM Thread Starter
Nickp's Avatar
First Name: Nick
Thanks, Paul...I appreciate the perspective...and how it changes based on need...
Nick
Points to Ponder...
Nickp is offline
post #34 of 39 (permalink) Old 05-08-2019, 09:21 PM
firesurfer's Avatar
When getting a gun, the most important thing is to try to get sticks that you can use. Odd sizes are a pain. Most use what I always thought was 1/2". Turns out they are really 7/16" (.44") Amazon has them really cheap. 5lbs. for $18. I used to get them in Manhattan at shops that cater to the garment industry but amazon is now more convenient. The odd uses for them just keep on surprising me, like bodywork on a car. (for pulling sheet metal without damage to paint)
Adtech Full-Size Multi-Temp 5-lb BOX All-Purpose Glue Sticks-7/16"X10" 5lb 10 inch, Clear $17.75
Nickp and tulowd like this.
firesurfer is offline
post #35 of 39 (permalink) Old 05-10-2019, 02:34 PM
First Name: JJ
Have an older corded Surebonder gun my dad used and I recently picked up the Ryobi 18V ONE+™ Hot Glue Gun
Model: #P305. Wanted to have the option of not being tied to a cord. It will also accept different nozzles from Surebonder.
Nickp likes this.
Flipsaw is online now
post #36 of 39 (permalink) Old 05-13-2019, 04:46 AM
le meilleur
dimo30 is offline
post #37 of 39 (permalink) Old 05-13-2019, 04:56 AM
Originally Posted by dimo30 View Post
le meilleur
the best what or which one???
post #38 of 39 (permalink) Old 05-13-2019, 06:29 AM
hawkeye10's Avatar
First Name: Don
Originally Posted by DesertRatTom View Post
My wife has one somewhere from her crafting days. I don't see a whole lot of use for one in the shop. Most of the time double sided tape does the job for me. Mostly I was reacting to that expensive one Stick suggested.
Tom, I have a really old cheap glue gun that I am using more and more. I find using double stick tape is hard to do if you are wanting to place a piece of wood in a certain spot and you can't be off any. also on some glue-ups, I use hot glue to keep the wood from moving around. It's one of those tools that if you can find it and get it out where it's handy you will find a lot of uses for it.
Nickp likes this.
Don in Murfreesboro,Tn.
hawkeye10 is online now
post #39 of 39 (permalink) Old 05-13-2019, 08:01 AM
You don’t have to use a glue gun either. You can fire up a torch and melt the sticks with that. By the way, the strongest hot melt I know of is made by Bohning who sell the sticks for attaching points to wooden arrows. It doesn’t fit in a glue gun.
Nickp and Herb Stoops like this.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Flipsaw
Thanks to Frank for this one harrysin Lobby 12 07-28-2017 05:32 AM
Hot glue? hawkeye10 Tools and Woodworking 9 11-13-2015 08:46 PM
Hide Glue Daikusan Tools and Woodworking 9 02-11-2014 06:47 AM
