Hot Glue Gun Recommendation...? - Router Forums
 34Likes
post #1 of 39 (permalink) Old 05-01-2019, 03:09 PM Thread Starter
Nickp's Avatar
First Name: Nick
Default Hot Glue Gun Recommendation...?
It's about time I got one...
Those of you that use hot glue guns, what do you recommend...?
Thanks in advance...Nick
Nick
Nickp is offline
post #2 of 39 (permalink) Old 05-01-2019, 04:22 PM
for what applications???
High or low temp???
dual heat???
mini or full sized???
what sized sticks???
what kind of output do you think you'll need???
DIY or industrial strength???
GP or fine tip???
multiple tips???
hard use or blue moon???
how many bases do you want to cover???
3M Polygun... it will outlast you and your grandkids...
TEC.. mid to upper level... good value... 805 or 820
Surebonder... GP...
BSTpower... versatile...
elcheapoes just don't last in a moderate to heavy use environment..
post #3 of 39 (permalink) Old 05-01-2019, 04:52 PM
kp91's Avatar
First Name: Doug
I have a cheap arrow gun..., it works pretty darn well (except it has a hard time standing up on it's own)
For under $20 it has held up for quite a while.
https://www.lowes.com/pd/Arrow-Singl...ue-Gun/1095639
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 39 (permalink) Old 05-03-2019, 06:51 PM
$209 seems a little steep for a glue gun for someone who is unsure of their likely uses. Looks like a number of decent ones are in the $30-$50 range. I'd buy this locally so you can get a stronger sense of what you're getting, how it feels, direct comparison of features.
DesertRatTom is online now
post #5 of 39 (permalink) Old 05-03-2019, 07:32 PM Thread Starter
Nickp's Avatar
First Name: Nick
Thanks, Tom...sounds reasonable...but I don't recall expressing that I was unsure of its likely use although it would have made sense to include my uses in the original post. For the most part it will be used in the shop and typical home gluing use. Probably to put together some unforeseen broken knick-knack or small crafts item...I typically buy locally just so I can put my mits on whatever it is I'm buying...
Certainly don't intend on using it for any heavy construction application...
I've never owned a hot glue gun and so I haven't missed it at all. But there is always some discussion about using hot glue here on the Forum that I thought I would buy one as I'm sure I will need another dust collector for the "unused tool shelf"...or I could leave it on the boat...
BTW, as long as I've got your attention, which one do you have...?
Nick
Nickp is offline
post #6 of 39 (permalink) Old 05-03-2019, 09:54 PM
JOAT's Avatar
First Name: Theo
I've got two. One larger, one smaller. Neither cost more than $10. Both work fine. I say that because I checked both to see that they work, and have never used either since. So you might want to start out real cheap, to see if you actually will use one or not. With me my fastening needs are well taken care of with Titebond II, crazy glue, duct tape, or nails. Can't think of a thing I would use hot glue for. Oh yes, mine were gifts - and I really wish people would ask me what I want before they buy me gifts.
Nickp likes this.
JOAT is online now
post #7 of 39 (permalink) Old 05-03-2019, 11:56 PM
I use mine occasionally when I need a quick bond that can be taken apart later or to hold something while a better glue hardens. For example when I make extra table saw inserts I hot glue the factory one to some mdf and use a pattern bit to route it to size. Same goes for quick and easy jigs. Hot glue them together and if you need extra hold add regular glue or brads or both. Get one and use it for a few things like that and you’ll probably start seeing other possibilities.
MEBCWD, Nickp and Herb Stoops like this.
post #8 of 39 (permalink) Old 05-04-2019, 12:34 AM
I have one and a whole bunch of different colored glue sticks that came in a batch of stuff I bought ,to get another item. I have never used it ,don't know what sticks to use for what. but with Sticks pdf I might figure out what and when to use it. thanks ,Stick for posting that.
Nickp and jj777746 like this.
Herb Stoops is offline
post #9 of 39 (permalink) Old 05-04-2019, 01:53 AM
My wife has one somewhere from her crafting days. I don't see a whole lot of use for one in the shop. Most of the time double sided tape does the job for me. Mostly I was reacting to that expensive one Stick suggested.
post #10 of 39 (permalink) Old 05-04-2019, 02:05 AM
So go find it and tell us what you use..
if you investigate the listed brands theyare selling from 10/15 bucks to over a thousand...
the point being w/o knowing what Nick's needs were all bases were covered..
Nickp likes this.
Thanks to Frank for this one harrysin Lobby 12 07-28-2017 06:32 AM
Hot glue? hawkeye10 Tools and Woodworking 9 11-13-2015 09:46 PM
Hide Glue Daikusan Tools and Woodworking 9 02-11-2014 07:47 AM
