DC enclosure project - Page 3 - Router Forums
 38Likes
post #21 of 26 (permalink) Old 06-11-2019, 06:07 PM
Contributor of the Month
JFPNCM's Avatar
First Name: Jon
As with you and many other member here, basically grew up with the trades. One of my first mentors told me when I was still in grade school, “ regardless of how much formal education you pursue, learn a trade and you will always have opportunities”.
Jon
JFPNCM is offline
post #22 of 26 (permalink) Old 06-11-2019, 07:01 PM Thread Starter
That was good advice. Have a time crunch on a different project just now, so I've closed off the breezeway without connecting the DC. Have to seal in the floor first. Moving slow these days.
DesertRatTom is online now
post #23 of 26 (permalink) Old 06-11-2019, 11:47 PM
JFPNCM's Avatar
First Name: Jon
Nothing wrong with moving slow. That is the value of being retired.
kp91 and DesertRatTom like this.
Jon
JFPNCM is offline
post #24 of 26 (permalink) Old 06-24-2019, 12:39 AM Thread Starter
Finally got back to the DC enclosure project today. Pulled everything out of the space, swept it up then cut two 45 degree cuts on some 1x6 and closed the galp between floor and shed wall. Once that was done, I laid down some linoleum on the floor, which is to keep the ac/heated air from excaping, but also makes cleanup easier. Tentatively hooked up the DC and Super Dust Deputy. Not quite the way I want it, but I'll be finessing it later in the week.
Still working on sealing the space in, and the doors aren't quite fitting on one end. Next major step is cutting an opening to vent the filtered air back into the shop. I made a hanging filter unit that hangs in the shop, has a 20 inch box fan in it, but it has two 20x20 filter holders on it. These will be going over the return opening so I'll have a double filter for the returning air, and a really large area for the return air. I ran out of daylight, so I'll take a picture or two tomorrow. Looks kind of cool in there. Might also install some insulation in the ceiling to hold down the heat a bit. Final bit will be sealing cracks with a fire resistant foam.
It all worked really well when I gave it a test run. I think I'm going to paint it and try to make it look nice.
Still managed to get in two naps.
post #25 of 26 (permalink) Old 06-24-2019, 07:36 PM Thread Starter
Project on hold for a couple of days to get things ready for a seminar in Charlotte. Also hope to get my church theater conversion project underway this week. A 16 x24 foot stage is OK'd and in the works. Just need volunteers with nail guns now.
post #26 of 26 (permalink) Old Today, 01:43 AM Thread Starter
Wednesday afternoon I'll be done with chores and can get back to the project. Trimming some areas out, sealing all the cracks, shortening the connector between SDD and shed outfeed, cutting the opening for the air return. I think I'm going to add some sheet insulation to the ceiling with radiant barrier to see if I can keep the heat down.
Anyway, it's really coming along. With everything connected again, I can clean up the sawdust that accumulated while the DC was down.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DesertRatTom
Plane Till Project schnewj Show N' Tell 17 10-11-2015 11:36 AM
Second Major Project - Kitchen Cabinets (in the addition) riffin-rich Show N' Tell 5 06-18-2013 03:06 PM
College Machining Project seater CNC Routing 4 02-24-2013 01:10 PM
woodworkers journal project reds_21 Tools and Woodworking 3 02-06-2005 09:09 AM
