Drying wood in a microwave - Router Forums
 26Likes
post #1 of 16 (permalink) Old 05-17-2019, 08:23 AM Thread Starter
First Name: Art
Default Drying wood in a microwave
I was given several hundred BF of oak that was cut at least 5 years ago and air dried. The problem is that it still feels wet. I know "get a moisture meter" which I will should I ever decide to use it on a major project. For now though I have sliced some 1/4" x 4" boards that I want to make small boxes out of. Does anyone have any suggestions on making sure the wood is dry by putting it in a microwave for a few seconds? Since the pieces will only be about 5" long and 1/4 thick it seems like it would be feasible.
mgmine is offline
post #2 of 16 (permalink) Old 05-17-2019, 08:39 AM
Gene Howe's Avatar
First Name: Gene
Might work. But, a few minutes in a low heat (250°) oven would be safer. Trapped moisture in a microwave could be disastrous.
jj777746, artman60 and OCEdesigns like this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 16 (permalink) Old 05-17-2019, 09:04 AM
Pay attention..
and BE VERY CAREFUL...
you can start the wood on fire internally..
Set the microwave on its lowest setting. On most microwaves, this is "defrost" or lower. Whatever your microwave's settings, choose one that runs on roughly 200 to 360 watts.
Place the wood on the outer edge of the carousel plate so that it rotates around the cavity of the microwave. Place two to three paper towels underneath the wood to absorb the moisture the wood gives off as it dries. You may place more than one piece of wood in the microwave at a time as long as they fit on the outer edge of the carousel and none of the pieces touch each other (touching pieces may ignite).
Microwave the wood for 1 ~ 1˝ minutes. (way less for thinner wood) Never leave the wood unattended while it is drying. If you notice smoke, stop the microwave immediately as you may have an internal fire...
Remove the wood from the microwave with oven mitts or heavy work gloves. Place the wood on the counter to release the steam.
Lift the wood off of the counter after 30 seconds to check the amount of condensation underneath the wood. Then allow it to cool to room temperature and to release the moisture removed by the microwave.
Repeat until little the wood produces little condensation while it cools down to room temperature. Do not try to nuke away all of the condensation. If the wood is too dry, it may smolder or ignite internally....
https://www.woodworkweb.com/woodwork...od-drying.html
mgmine, jj777746 and artman60 like this.
Stick486 is offline
post #4 of 16 (permalink) Old 05-17-2019, 09:07 AM
the more gooder way...
but over ''drying'' will case harden the wood...
Stick486 is offline
post #5 of 16 (permalink) Old 05-17-2019, 09:11 AM
harrysin's Avatar
First Name: Harry
I have a friend who has used a microwave for many years without problems but a moisture meter is essential and so cheap these days.
https://www.ebay.com/sch/i.html?_fro...+wood&_sacat=0
The US price is much lower.
mgmine and jj777746 like this.
Harry
harrysin is offline
post #6 of 16 (permalink) Old 05-17-2019, 09:43 AM
First Name: Gary
Harbor Freight has cheap moisture meters
Herb Stoops likes this.
gmercer_48083 is offline
post #7 of 16 (permalink) Old 05-17-2019, 10:28 AM
Knothead47's Avatar
Hot items can separate laminate and the base material or melt an acrylic as Corian. Put the wood on a wire rack to cool all sides.
Had a fellow who came into the cabinet and lighting gallery where I worked. His wife was out of town. He took a pan off the stove and, not thinking, put it on the Corian countertop. Melted a nice circle about 8 inches in diameter. Owner had to contact someone to repair it.
harrysin likes this.
John T.
Knothead47 is offline
post #8 of 16 (permalink) Old 05-17-2019, 06:20 PM
First Name: Gary
Art, Chances are the wood is dry enough after 5 years. Acclimate for a week or two, then use it. Or make sure with a moisture meter. A moisture meter will give you a reading on that side of the lumber (not the entire thickness). Once the lumber is shaved to thickness...it will release tension if it has a lot of moisture. I say see what happens.
kp91 and artman60 like this.
post #9 of 16 (permalink) Old 05-17-2019, 09:00 PM
JOAT's Avatar
First Name: Theo
I have never wanted, needed, or tried, to dry wood in a microwave. But when I first heard about that, I did a lot of reading on it. Forgot 99% of what I found out, but do recall that some of the wood was put in a paper bag with sawdust in it, then covered with sawdust, and dried in the microwave, don't recall any details. Seems to me that was used for green wood. What I do know is, if I wanted to dry wood with a microwave, I'd do a lot of reading of material posted by people who had actually done it. You'll also read about the mistakes many made learning how to do it.
However, it is most likely the wood is totally, ruined if it feels damp after 5 years, and utterly worthless to use. Your best bet is to forward it to me, for appropriate sacrifice to the Woodworking Gods - I am a High Priest, and will take care of all details. There is a time window on proper sacrifices, so send it quickly.
Kiddies, do not try this at home.
harrysin and jj777746 like this.
JOAT is online now
post #10 of 16 (permalink) Old 05-17-2019, 09:03 PM
I’ve seen a wood technologist check samples for moisture content by microwaving for 20 seconds at a time I think and then weighing it. When it stops loosing weight it’s dry.
harrysin, MEBCWD and jj777746 like this.
Planning projects for wood movement Duane Bledsoe Tools and Woodworking 27 10-13-2015 09:39 PM
Wood Species dattashri Wood Species 7 07-26-2012 10:23 AM
Exterior wood Treatment dattashri The Finishing Touch 3 05-14-2012 11:37 AM
Beginner Wood.. New Pupil.. Nef003 Tools and Woodworking 26 03-09-2012 12:10 PM
