Should I go cordless? - Page 5 - Router Forums
 58Likes
post #41 of 66 (permalink) Old 05-30-2019, 04:25 PM
First Name: Larry
Biagio, I run a commercial shop that drives a lot of screws. We use the top of the line Makita battery impact drivers. Extremely durable and far better than the contraptions called "drill drivers." Once you are used to them you can easily control how deep they set the screws. For something I rarely use I'd stick with a corded tool. I've got a corded Bosch SDS hammer drill that has been good.
Biagio likes this.
Larry42 is offline
post #42 of 66 (permalink) Old 05-31-2019, 04:29 PM Thread Starter
First Name: Tim
Got sick of it and bit the bullet.
Ordered a cordless Bosch rotary hammer, it came with a charger, battery, and an impact wrench, all 18V. Thinking of getting the 18V sander as well.
It seem to make sense to stay in the system and get another battery and an 18V saw. But for the same money I could get a wimpier but smaller Bosch/Makita 12V saw, drill, their batteries and charger. I shouldn't prefer the later, but for some reason I do.
I would prefer to keep them all blue so that it doesn't offend my aesthetic, but I suspect the 12V Bosch might have a small ergonomic problem because it can't stand upright on its grip like the Makita.
If my therapist is ineffective I might get the oscillating multi tool as well.
vchiarelli likes this.
Navyblue is offline
post #43 of 66 (permalink) Old 05-31-2019, 09:20 PM
JOAT's Avatar
First Name: Theo
No problem. Paint them. My tools get painted bright yellow; helps brighten the shop, and makes it feel sunny.
Call me a craftsman, artisan, or artistic, and I will accept that. Call me an artist and you will likely get a quite rude comment in return. I am not a @#$%ing artist.
JOAT is offline
post #44 of 66 (permalink) Old 06-01-2019, 03:25 AM Thread Starter
First Name: Tim
I’ll see if I can find “Bosch blue” in the paint catalog, if not this is a deal breaker for me.
Navyblue is offline
post #45 of 66 (permalink) Old 06-03-2019, 05:55 AM
OldCurmudgeon's Avatar
First Name: Ely
Originally Posted by honesttjohn View Post
And like marriage ...... the batteries eventually wear down.
But batteries are much easier (and cheaper) to replace...
honesttjohn likes this.
One year of experience repeated 10 times is not 10 years of experience.
OldCurmudgeon is offline
post #46 of 66 (permalink) Old 06-03-2019, 06:01 AM
First Name: Ely
The Bosch 12V drill / impact driver duo may seem weaker than 18V tools, but it's doing excellent work in my shop and they are much lighter (and easier on the wrist) than my 18V Ryobi. I use the drill for pre-drilling and the impact driver to drive the screws (duh...) and don't have to change bits. It's true, however, that these tools can't stand on their own, unlike most of the 18V tools.
Navyblue likes this.
post #47 of 66 (permalink) Old 06-03-2019, 08:03 AM
True -- especially the cheaper part.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #48 of 66 (permalink) Old 06-04-2019, 06:49 PM Thread Starter
First Name: Tim
I guess it is safe to say that the primary usage of drill/impact driver on woodworking is for screws.
Personally I deal with mostly small screws around 1", at most 2". 12V is plenty for those.
The 18V rotary hammer I got is 7lb, the 18V impact wrench that came with it is 4lb, all without batteries. If they offered the 12V impact driver or drill as a choice I would have picked them. As it is now it is a little hard to justify a whole new platform for just a single drill (I think I might be getting the 18V saw for the versatility). That said the drill will probably be my single most used power tool.
Navyblue is offline
post #49 of 66 (permalink) Old 06-06-2019, 01:09 PM
A battery operated circ saw is a pleasure to use. Not good for construction where you're chopping up heavy, wet lumber all day long, but so easy to pick up and use with a guide to cut up ply on the fly. Used it yesterday to trim off a 1/4 inch from the top of a door. Quick and easy. It's a DeWalt. Recently found the 18v batteries on sale for $100, far cheaper than the $150 a pair at HD. I had a local battery company rebuild a Makita battery pack and they did a poor job, used undersized batteries. Has anyone had a DeWalt or other bramd battery rebuilt and how well it worked. In theory, it should be fine.
DesertRatTom is online now
post #50 of 66 (permalink) Old 06-06-2019, 03:36 PM
JOAT's Avatar
First Name: Theo
Default OK, I'm convinced. I'm willing to go cordless, the right way.
After much thinking about it, have decided that if I'm going to go cordless, to go all the way. I figure one of these is a good place to start.
JOAT is offline
Cordless routers for round overs MGildersleeve General Routing 13 01-25-2018 07:22 AM
Cordless Drill Recommendation CanuckGal Tools and Woodworking 57 08-10-2009 08:59 PM
RIGID 1/2" Cordless Drill Noddy Tool Reviews 8 10-05-2007 03:27 AM
