Jig Saw issue - Router Forums
 20Likes
post #1 of 19 (permalink) Old 06-05-2019, 08:56 AM Thread Starter
First Name: bill
Default Jig Saw issue
- i have an old Craftsman variable speed jig saw purchased several decades ago. It runs well and only gets occasional use. It has a "feature" that makes me contemplate its demise each time I do use it.
- when making curved cuts in thicker material <say anything > 3/8" it puts a significant 'bevel' on the cut. In other words, it does not make a true vertical cut. I suspect part of the issue is that the distance from the blade mount to the bottom of the plate <which would be the top surface of the wood when cutting>. It seems big compared to pics of newer jig saws. Its apx 1-5/8". In my mind, a shorter distance would put the wood closer to the blade mount and resist the blade 'flexing' when cutting curves.
- I don't think I am feeding the material too fast <pushing too hard> and fast or slow feed or, fast or slow rpms seems to make no difference to its natural ability to bevel the inside of a curve.
- I am off base thinking a new one <either orbital or regular> is going to give me clean(er) curves or is this one of those "they all do that to some degree" things ??
- ebill
ebill is offline
post #2 of 19 (permalink) Old 06-05-2019, 09:19 AM
JOAT's Avatar
First Name: Theo
I have a B&D I bought in maybe 1976. Works fine. But the blade holder, or whatever it's called, is a bit worn now. Cuts straight, but curves are not straight up and down. No biggie, I never make finishing cuts with one anyway, old OR new, just straight cuts, or rough cuts; then I sand to the line. If you don't want it anymore send it along to me. I can use it with no issues.
JOAT is online now
post #3 of 19 (permalink) Old 06-05-2019, 09:41 AM
I have a newer Craftsman and it does the same thing. The blade even looks out of square with the the table by 10 degrees. I can't seem to get it square,so don't use it. I bought a cordless Makita and am very happy with it. I had an old craftsman that had the scroller feature on the blade that I could rotate while cutting, was very handy cutting out vanity tops for sinks. The newer craftsman had the same feature ,but was not cutting square. I only use mine for rough cuts too.
Herb Stoops is offline
post #4 of 19 (permalink) Old 06-05-2019, 10:16 AM
Gene Howe's Avatar
First Name: Gene
My Bosch cuts nice curves in 3/4 and, thinner material. My old Craftsman would deflect, though. I only use Bosch blades. They seem stiffer.
Barry747, TenGees and Herb Stoops like this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #5 of 19 (permalink) Old 06-05-2019, 10:41 AM
NO BLADE GUIDE STABILIZER...
move to the head of the class and go w/ a Bosch...
Stick486 is offline
post #6 of 19 (permalink) Old 06-05-2019, 11:13 AM
TenGees's Avatar
First Name: Paul
Some jig saws have a blade guide above the plate which helps them make straighter cuts. As Gene mentioned, the blade quality also matters.
Herb Stoops likes this.
TenGees is offline
post #7 of 19 (permalink) Old 06-05-2019, 11:43 AM
vchiarelli's Avatar
First Name: Vince
Is the shoe getting loose and tilting the saw? The other issue might be that the blade is bending as you make the curve and causing the bevel.
vchiarelli is offline
post #8 of 19 (permalink) Old 06-05-2019, 11:55 AM
kp91's Avatar
First Name: Doug
quick fix- better blades and slow down your feed.
long term fix, better saw.
Always check the classifieds like Craigslist for jig saws. There are some very decent ones on there for $50-ish, just keep your eyes open.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #9 of 19 (permalink) Old 06-05-2019, 12:17 PM
I have an 18v DeWalt. Has a guide and only use Bosch blades, and the shortest blade that will do the job. Does a good job on straight and curved cuts, although I always sand the curves in particular. I also don't push the cut fast. Not having to monkey with a cord is a real plus. Can't quite justify a Bosch at this point, but if the DeWalt dies before I do, I'll probably stretch the budget for a Bosch.
post #10 of 19 (permalink) Old 06-05-2019, 12:55 PM
Knothead47's Avatar
Coping saw solves the problem. Sounds like the blade is flexing. I h ave an ancient CM jigsaw that was my late father-in-law's. Metal case tells you how old it is. Never had a real problem with cutting even thick stuff. I use it for rough cutting and use a sanding drum for the finish work. The goal/hamper is an example. Cut with the jigsaw and used a drum sander on the drill press to go up to the line.
John T.
Knothead47 is offline
