Ryobi BS901 9" Bandsaw Parts - Page 2 - Router Forums
 5Likes
post #11 of 18 (permalink) Old 07-06-2019, 10:07 AM
I like the Timber Wolf brand for my small saw. Although you can get a 1/8th blade for fine work, they are fragile, particularly if over tensioned. I prefer the 3/16th for a small blade. My blades are 72 inches long so they last a little longer than the shorter ones. I keep a half inch, 4TPI blade mounted for general use. The Timber Wolf blade makes a very nice cut. Lenox also gets good reviews.
JIMMIEM likes this.
post #12 of 18 (permalink) Old 07-06-2019, 10:55 AM Thread Starter
Thank You!!
JIMMIEM is offline
post #13 of 18 (permalink) Old 07-19-2019, 06:30 AM Thread Starter
Quick update. I saw some blogs about making band saw tires from bicycle inner tubes or black friction tape. I figured I'd try the friction tape trick. I wanted to make sure this tool would even work before I put any more $ into it. The top tire was missing when I got the saw. The bottom tire was intact. I friction taped the top tire. On the first cut the bottom tire broke so I wound up doing the friction tape thing to it. One upside to removing the wheels was that I got to look around inside, see how it was put together, and do a real good cleaning job. I ran it a little bit with the friction tape tires and junky Bosch blade and it did ok with the cuts. I get why you folks consider this to be a 'toy'. I'll use it for small stuff.
Thank You for your help!
JIMMIEM is offline
post #14 of 18 (permalink) Old 07-19-2019, 09:53 AM
It still has it`s uses Jim. My SIL bought a 9 or 10 inch Ryobi not long ago and I needed to use it when I was there remodeling. I was surprised at how quickly it cut what I needed. It should work perfectly well for cutting out patterns or tapering legs and small jobs like that. You won`t be resawing 2 x 6s with it. As long as you got a good deal on it it should be a useful addition to the shop.
JIMMIEM likes this.
post #15 of 18 (permalink) Old 07-19-2019, 12:20 PM
old coasty's Avatar
First Name: Bob
I don't know if you have an ACE Hardware store there, but I found OLSON TKO Benchtop saw blades at mine. Several choices in 1/4" and 3/8". The package saws OLSON makes them in 4 to 14 TPI and with Skip, Hook and Regular teeth.
Might be worth Googling OLSON.
" Age is an issue of mind over matter. If you don't mind it doesn't matter. "
Mark Twain
old coasty is offline
post #16 of 18 (permalink) Old 07-19-2019, 12:24 PM
old coasty's Avatar
First Name: Bob
Just looked, AMAZON has quite a few 59-1/2" blades
DesertRatTom likes this.
Mark Twain
post #17 of 18 (permalink) Old 07-19-2019, 12:36 PM
I got my blades from Amazon. Not a bad selection, and I like the free shipping.
JIMMIEM likes this.
post #18 of 18 (permalink) Old Yesterday, 06:12 AM Thread Starter
Thank You. Amazon has become our 'go to' place for buying stuff. I prefer to shop locally at the small 'mom and pops' but the on-line prices and selection are unbeatable. I don't like the Big Boxes either.
But, I went to my local hardware store to buy the black friction tape for the band saw tires and they didn't have it....will order it, but it won't be available for a week......Lowes had it.
JIMMIEM is offline
