Motor speed - Router Forums
 15Likes
  • 1 Post By Stick486
  • 2 Post By roxanne562001
  • 3 Post By roxanne562001
  • 5 Post By CharleyL
  • 3 Post By harrysin
post #1 of 10 (permalink) Old 07-12-2019, 05:45 PM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Default Motor speed
I have a 1 hp 3450 RPM motor, that I want to use to replace a 1/4 hp lathe motor, it's way under powered. Thing is, the old motor is only 1725 RPM. It has a step pulley, and I can't really get the smallest pulley any smaller so I can't reduce speed with "gearing". Is there a way to reduce the 3450 RPM at the motor?
Afraid I already know the answer, but thanks anyway.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 10 (permalink) Old 07-12-2019, 06:24 PM
multi drive system, pulley reduction or a transmission...
MEBCWD likes this.
post #3 of 10 (permalink) Old 07-12-2019, 06:25 PM
JOAT's Avatar
First Name: Theo
Jackshaft.
JOAT is offline
post #4 of 10 (permalink) Old 07-12-2019, 06:27 PM
you do realize that the mega increased torque will more than likely tear your lathe apart...
go get a half horse w/ the correct frame...
DesertRatTom likes this.
post #5 of 10 (permalink) Old 07-13-2019, 09:05 AM
roxanne562001's Avatar
First Name: Roxanne
I thought you might find this interesting https://www.cnccookbook.com/variable...c-lathe-motor/ If I was going to go through the work of changing the motor I would replace it with a DC motor that way you can have infinite variable speed.
harrysin and Stick486 like this.
roxanne562001 is offline
post #6 of 10 (permalink) Old 07-13-2019, 09:24 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Jack, EBay has heaps of electronic speed controllers suitable for AC motors, prices are so low that it's worth trying. Copy and paste this link for examples.
New 4000W 100V-220V AC SCR Voltage Regulator Motor Speed Control Controller 2019
Harry
harrysin is offline
post #7 of 10 (permalink) Old 07-13-2019, 10:46 AM
First Name: Roxanne
Harry I don't think you can use an SCR speed controller with an AC motor that doesn't have brushes. The speed is controlled by the AC cycles going through the windings on most AC motors. The SCR controller adjusts the voltage. I don't think that an SCR controller will work with the type of motor he is asking about.
harrysin, Stick486 and Old_Tom like this.
post #8 of 10 (permalink) Old 07-13-2019, 12:13 PM
CharleyL's Avatar
First Name: Charley
@ Roxanne and the rest of you,
A DC motor loses torque as you reduce it's speed, unless you have a special power supply to control it and a small tachometer/generator attached to the motor shaft to send motor speed information back to the power supply. The power supply then compares the motor shaft speed desired to the actual speed and increases or decreases the power being fed to the motor. This is especially helpful when the motor load is changing but the speed must be kept constant. Only enough power is fed to the motor to overcome friction, plus what it takes to keep the motor running at the correct speed, so it runs very cool with no load and progressively warmer as the load increases.
I once was involved in the design of a motor drive system that could accelerate a DC motor to 4,000 rpm in 1/2 revolution and then decelerate it to a stop, back on the "home" position where it started, and it needed to do this ten times a second. Sounds outrageous doesn't it? I had to have a special low inertia hollow field rotor motor built for this purpose that was liquid cooled because I was pushing almost 40 amps into the motor for 1/2 revolution, and then again in reverse polarity to decelerate and stop it. This motor drives an eccentric (crank shaft) to move a 40 lb assembly 0.040" down and back up with an equal 40 lb weight moving in the opposite direction and back the same distance that acts as a counterweight to keep vibration down.
These machines are part of the manufacturing line that builds the multi-layer ceramic circuit boards for the IC chips to attach to that are the CPU modules in computers and cell phones today (look for the light purple color ceramic). A similar motor control design drives the motors in the Apollo Lunar Rover, and I was a bit involved in those too.
Inductive type AC motors are frequency dependent. Special control systems change the frequency of the power going to the motor, but the power level is relatively constant to maintain torque. The frequency of the AC power and the number of poles in the motor determines the motor speed. Three phase motors are fed power by three inputs with the sine wave of each input delayed from the previous by 120 degrees or multiples of that. A three pole motor will rotate 360 degrees when the 3 phase power fed to it completes one complete sine wave. A 6 pole motor will complete 1/2 revolution with one complete sine wave. So the number of poles of the 3 phase induction motor is determined by the frequency of the AC power and the number of poles that the motor has in it's design. A stepping motor increments from pole to pole as you switch and change the polarity of the DC power being fed into it. Some, with the right control design can be used as a slow speed frequency controlled motor
Clear as mud, right? I've spent most of my working career in machine control systems design. Face it every day and it grows on you.
This is also why I play with trains and wood now.
@Jack ,
You aren't going to be able to change the motor speed without changing the motor. Stepping the speed down through pulleys or gears is the only way to get the speed that you need if you go with that motor. It would be best and likely cheaper to just go with a motor that has more horsepower and is designed to run at the correct speed. You can't buy a controller for a small single phase induction motor, because the starting circuit in the motor will kick in at about 40% of speed and it will burn up if engaged for more than about 30 seconds.
Charley
Central North Carolina
CharleyL is offline
post #9 of 10 (permalink) Old 07-14-2019, 07:04 AM
harrysin's Avatar
First Name: Harry
You are of course quite correct, I assumed that, like my lathe we were talking about a universal motor, and, still assuming that here is a speed controller that would be perfect and the cost in the US much lower. My lathe has a stepped pulley and the electronic speed control.
https://www.banggood.com/120V-15Amps...r_warehouse=CN
EDIT...Forgive me Roxanne for failing to mention how impressed I am with your knowledge.
Harry
harrysin is offline
post #10 of 10 (permalink) Old 07-18-2019, 11:39 AM
First Name: martin
find a thrown out treadmill that works. they have a 1HP brushed motor with a speed control with a feedback loop, very nice. the one that I have has fans on both shafts, one to cool the motor, and one to cool the speed control..
radios is offline
