Have you ever had this issue? - Page 2 - Router Forums
 37Likes
post #11 of 17 (permalink) Old 07-20-2019, 03:56 PM
First Name: Dick
Originally Posted by papasombre View Post
Hi, guys.
I love Elmer's wood glue but, it seems to me that there is a problem with the dispenser tip.
On my last trip to the USA, I bought four bottles of this glue. When I was using my first bottle during one of my projects, the dispenser did not slide over the tip and the cap was broken. I put a coin inside the cap to protect the glue from drying and contaminants.
A similar situation happened with the second bottle. This time, I pulled the dispenser off and the orange ring on the tip brake down.
In both cases, I needed to remove the cap to pour the glue in the joint making this not even and spillage prone.
I googled some information about this and it looks like this is a common problem with this brand.
Having two additional bottles in stock, It seems to me that I need to take care of the bottle's cap when the time to use them arrives. Another option is to use Titebond again but both brands are not available here. Local glues are expensive and look like the same product with different names.
Assuming these bottles flew to Venezuela in the cargo hold of an airplane, they could have been exposed to some very cold temperatures, and the plastic could have been damaged. Maybe the glue too ...
dicktill is offline
post #12 of 17 (permalink) Old 07-22-2019, 08:53 AM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
That is a good point, Dick.
That was not the case since the glue, along with other supplies arrived in my country by sea. The joints that I have glued are strong meaning that the product is good.
I will start to use the third glue bottle and just in case, I told to my wife to keep the mustard bottle that she is using.
marecat3 likes this.
We, woodworkers are everywhere!!!
papasombre is offline
post #13 of 17 (permalink) Old 07-25-2019, 12:14 AM
firesurfer's Avatar
This is my favorite.
firesurfer is offline
post #14 of 17 (permalink) Old 07-25-2019, 01:08 AM
jj777746's Avatar
Some good responses here Alexis.I'm interested to find if lids from condiment squeeze bottles fit your Elmer's glue bottles? This would be the simplest method & no wastage.Good luck with whichever way you choose. James
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #15 of 17 (permalink) Old 07-25-2019, 04:25 PM
kp91's Avatar
First Name: Doug
I use the gluebots from fastcap and buy glue in the bulk jugs
https://www.fastcap.com/product/glubot-family
papasombre likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #16 of 17 (permalink) Old 07-27-2019, 01:34 PM
hankh's Avatar
Country: Israel
First Name: Hank
I don't usually use Elmer's, but I have a bottle now. I can't pull it open by hand even when I clean off the dried glue from previous jobs. So I simply use a plier. Works fine, but shouldn't to do it this way. In the past I have used a catsup bottle and it works fine. I like the ones that are made to stand on the spout side - ready to use immediatley.
hankh is offline
post #17 of 17 (permalink) Old 07-27-2019, 01:55 PM
Originally Posted by JFPNCM View Post
Keep my tight bond III bottles turned upside down after I wipe the tips off. Seems to work for me. Otherwise the mustard and ketchup bottles are great. Just make sure you keep the hotdogs and hamburger out of the shop. ��
Party poop!
JFPNCM likes this.
DaninVan is offline
