How is this made? - Page 3 - Router Forums
 27Likes
post #21 of 31 (permalink) Old 07-22-2019, 09:20 AM
mimac's Avatar
First Name: Brian
From the looks of the age and size of that post I would say the lamb's tongue was cut with a turning frame saw (ancestor of the coping saw, larger and more robust).
mimac is offline
post #22 of 31 (permalink) Old 07-22-2019, 10:07 AM
Lots of ways to skin that cat. A one off, I'd do with hand tools.
post #23 of 31 (permalink) Old 07-22-2019, 04:33 PM
Nickp's Avatar
First Name: Nick
It seems to me a good sized 45deg bit would do the whole thing...except for the transition between the two sections...
It will cut the 45 on the length and it will cut the small section with the radius cutting the curve at the end. Then a bit of handwork/sanding to smooth the transition...
gmercer_48083 and Herb Stoops like this.
Nick
Nickp is online now
post #24 of 31 (permalink) Old 07-23-2019, 01:59 AM
Contributor of the Month
Country: South Africa
First Name: Biagio
I must say that for four lamb tongues, I would reach for the Dremel planer attachment. I believe it is about $20 in the USA, cuts 2,25 inch wide. Might hav to clean up the end of the cut near the 45 degree chamfer by hand, but should be little work.
There use to be a similar drill-driven concept, but I cannot remember who made it - think it was Wolfcraft, but if so, no longer.
Biagio is offline
post #25 of 31 (permalink) Old 07-23-2019, 06:28 PM
CharleyL's Avatar
First Name: Charley
I did it about 50 years ago with a router and 45 deg bit. Then followed up with a very sharp chisel to carefully hand carve the lambs tongue at each end. Then repeated the process on all for corners. It was for a very fancy Colonial post replacement that had to duplicate the original as close as possible. I didn't install it, just made it. No pictures...sorry.
Charley
Central North Carolina
CharleyL is offline
post #26 of 31 (permalink) Old 07-24-2019, 05:39 PM
First Name: Don
Given the age of the post, it is likely that a hand plane was used to cut the chamfer. The lamb's tongue was probably created using a jig, for the sake of repeatability and speed, though, as previously shown a chisel can do it. Likely a rasp could, too.
friendly1too is offline
post #27 of 31 (permalink) Old 07-24-2019, 06:09 PM
First Name: john
The cut is called a lamb's tongue and I believe they are usually done by hand with a chisel.
johnjory is offline
post #28 of 31 (permalink) Old 07-24-2019, 06:20 PM
Probably done with a copeing saw in the day.
Herb Stoops likes this.
ventifact is offline
post #29 of 31 (permalink) Old 07-24-2019, 08:39 PM
First Name: ben
Default porch post trim
The attached photo shows five porch posts of about 30 that I did on my house about 25 years ago. The trim work was done after the posts were installed. It was done with a hand held router with a chamfer bit. The only jig was a top/bottom stop block. I did not do the fancy lamb's tail stuff at the beginning and end of the cut so it was not as fancy as the video someone posted. After doing the first post, I turned the work over to my son. Unfortunately, I sold that house about 3 years ago.
Name:	front portal.jpg
bfblack is offline
post #30 of 31 (permalink) Old 07-25-2019, 07:27 AM Thread Starter
First Name: Art
Looks a lot like what I'm doing
mgmine is offline
