How is this made? - Router Forums
 27Likes
post #1 of 31 (permalink) Old 07-21-2019, 08:42 AM Thread Starter
First Name: Art
Default How is this made?
Any idea how this was cut was made? Since the post is built up with 5/4 stick around a 4x4 the edge treatment must have been done after the post was built. I can guess that the bevel was probably made with a 45 degree bit but how was the transition to the curved part made?
mgmine is offline
post #2 of 31 (permalink) Old 07-21-2019, 08:51 AM
A Picture would be nice.
Herb Stoops is offline
post #3 of 31 (permalink) Old 07-21-2019, 08:53 AM Thread Starter
First Name: Art
I was editing the picture trying to get it turned right but it's still wrong...sorry
Herb Stoops likes this.
mgmine is offline
post #4 of 31 (permalink) Old 07-21-2019, 09:04 AM
boogalee's Avatar
First Name: Al
Try this.
mgmine likes this.
Al B
boogalee is online now
post #5 of 31 (permalink) Old 07-21-2019, 09:05 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Probably before the trim was added.
Harry
harrysin is offline
post #6 of 31 (permalink) Old 07-21-2019, 09:32 AM
I have problems like that too.
Is that a wood post, it has the appearance in my eyes as a concrete column. I have no idea how they were made other than by hand,they seem to have a curve rather than a flat chamfer.
post #7 of 31 (permalink) Old 07-21-2019, 01:04 PM
Band saw would do it, or a router and then a band saw or some sort of hand saw.
Lay a corner into a 90 degree cradle and cut most of the 45 degree cut, reverse it and cut the other half. Then use the band saw to cut a nice curve, while still in the cradle. In the field it could be done with a sabre saw, but there's less repeatability that way. Use a pattern to mark it up. The give away is the straight cut at the transition from the 45 cut to the curve.
Probably a job for an apprentice.
post #8 of 31 (permalink) Old 07-21-2019, 01:12 PM
RainMan 2.0's Avatar
A skil saw can go to 45 degrees ,and have a guide air nailed to the post . My other though was doing it the hard way with a router . Build a sled for the router that attaches to a 45 degree angle
mjadams61 likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #9 of 31 (permalink) Old 07-21-2019, 04:59 PM
Semipro's Avatar
First Name: John_*
Art
That profiles is called a lamb tongue ( I usually cut the 45 with a routr and finish with a hand chisel )
The video shows making a double tongue your profile is a single tongue if you practice with a sharp chisel you can learn to make that single tongue pretty quickly
I was able to find a video showing how to hand cut lambs tongue
Semipro is online now
post #10 of 31 (permalink) Old 07-21-2019, 07:38 PM
The post IS resting in a cradle. That was 12 minutes per lambs tongue, that's almost an hour per set of 4. At say $50 an hour, that going to be $80 in labor, plus whatever material. I think this could easily be done with a band saw, and done much faster. Unless, of course, you have a premium customer, or an appreciative wife, or just love hand work.
The cradle will hold the angle, the band saw blade set at 90 will cut the 45.
TenGees likes this.
