Compond Miter Saw Blades? - Router Forums
 4Likes
post #1 of 13 (permalink) Old 09-04-2019, 08:52 PM Thread Starter
sreilly's Avatar
First Name: Steve
Default Compond Miter Saw Blades?
So as I use my shop more and more I find myself using the Dewalt DWS779 sliding compound miter saw more and more for cutting my wood down to finished sizes. A prime example is while building the workshop stands and needing to cut the maple boards to finished length. What is questionable is the quality of cut the blade is giving. What is a good blade to use that's reasonable in price and quality to use on this 12" saw? I've been looking at a zero clearance plate for this saw as well to help. Suggestions?
sreilly is offline
post #2 of 13 (permalink) Old 09-04-2019, 09:03 PM
https://www.protoolreviews.com/tools...w-blades/4535/
https://www.fastcap.com/product/zero-clearance-tape
These might help.
Herb Stoops is online now
post #3 of 13 (permalink) Old 09-04-2019, 09:39 PM
Gene Howe's Avatar
First Name: Gene
Good blade review. Thanks, Herb.
I use the Tenryu Miter Pro in a Bosch SCMS. The review was accurate. It's a great blade. Well worth the bucks.
And, Herb's FastCap link to the ZC tape is another gem, too. The tape is good stuff.
Herb Stoops and jj777746 like this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 13 (permalink) Old 09-04-2019, 09:57 PM Thread Starter
sreilly's Avatar
First Name: Steve
Thanks Herb. I'll read over the reviews. As for the zc tape I had seen that before and thought building the plates might prove a good lesson. Also I know that Infinity Tools has a plate for this saw which may well be a good choice. I have the plate for the SawStop.
sreilly is offline
post #5 of 13 (permalink) Old 09-04-2019, 10:00 PM
Almost all blades (the decent ones anyways) have a lot of info printed on the blades now. Specifically whether they're appropriate for SCMS and radial arm saws.
DaninVan is offline
post #6 of 13 (permalink) Old 09-04-2019, 10:39 PM
I have one of those in 10" for the RA saw and a 12" for the TS they are great blades, give almost glass smooth finish .
Steve, the tape is not just a thin flimsy tape, it is stiff and ridged, I use it on my Bosch table saw. good stuff.
post #7 of 13 (permalink) Old 09-04-2019, 11:52 PM
Bob Adams's Avatar
First Name: Bob
I have a mom & pop blade sharpening service close by that I use to sharpen all of my blades. About 2 yrs ago I needed to replace the 12" blade on my slider and went to them for the purchase. The owner had a freshly sharpened used blade (one of several) on the shelf that was marked $25.00. Told me it had could be sharpened at 3 more times, and then sold it to me for $12.00, this is a 12" blade. I have cut a lot of wood with the blade and it is still going strong. The brand name has worn off, so I have no clue who made the blade.
If you have a sharpening service near by talk to them, they know their stuff. And who knows, you might get a great deal too.
Bob Adams is offline
post #8 of 13 (permalink) Old 09-05-2019, 12:47 AM
There are a few blades that have a slightly positive rake angle and I think the stock DW blade might be one of them. I feel safer with one that has a negative rake angle. The negative angle is supposed to help keep the board down on the saw table plus negative hook blades tend to splinter less. TS rip blades are the exact opposite with a lot of positive hook.
A couple of other points to consider. I had a chance to ask a Freud rep one day last year just what the differences were between the Diablo and Industrial lines. He said when all the other factors were equal (number of teeth, type of grind, full or thin kerf , etc) the only real difference was carbide thickness. So if you don't plan on sending them out for sharpening then the Diablo line is probably your best bet. The type of grind will make a big difference too. As Herb's article pointed out the Freud blade with Hi-ATB grind gave the best cut. But the Hi-ATB grind is also the most fragile too since the points are long and skinny. So you have to decide whether you may want to invest in blades that cut sharper or last longer or whether you may want more than one type and keep the Hi-ATB for really critical cuts.
MYB likes this.
post #9 of 13 (permalink) Old 09-05-2019, 12:54 AM
a little more information...
I'm partial to Freud...
CharlesWebster likes this.
post #10 of 13 (permalink) Old 09-05-2019, 01:46 AM
Had that 12 inch model and had a lot of blade deflection. Switched to full kerf blades and it helped some. Got rid of the saw and went with a 10 inch bosch instead. Currently keep a full kerf glue line blade on it. Baby behind smooth cuts. Also learned to pull the blade toward me to make a shallow first cut, then push it back for the full cutoff. This gives the sawdust a channel to fly out of so sawdust doesn't just go flying every which way. I have also used in the past an 80 tooth full kerf on the saw and got excellent results. The Glue line blade is really a rip blade at heart, but man, does it do a nice clean, smooth cut!
If you can manage it, a stiffener also helps keep the blade from deflecting. The problem showed up when trying to make angled cuts, eg: 45 degree miters for picture frames. Showed up on the 12 inch blade, no problem with the 10 inch. I tend to use Freud blades, the industrial models. Last forever and many sharpenings because the tips are thicker than the cheap models. Lots of good advice here.
