Kliss Clamp - Page 2 - Router Forums
 15Likes
post #11 of 15 (permalink) Old 09-11-2019, 11:33 AM
TenGees's Avatar
First Name: Paul
I remember seeing an idea for holding doors upright. The advantage of the clamp shown is how it handles different thicknesses, although you could use shims for the homemade one. This is like an extension of Chucks idea.
TenGees is offline
post #12 of 15 (permalink) Old 09-11-2019, 11:57 AM
instead of the hinge use a thin plywood cut cross grain...
TenGees and Herb Stoops like this.
Stick486 is offline
post #13 of 15 (permalink) Old 09-11-2019, 01:24 PM
kp91's Avatar
First Name: Doug
Originally Posted by sreilly View Post
Tried calling and no answer......probably out of stock and shipping maybe an additional $0.25. I'll bet gas was a lot cheaper then as well.........
It pre-dates the 5 digit zip code as well!
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #14 of 15 (permalink) Old 09-11-2019, 02:24 PM
for pocket screw assembly, I like using the right angle clamp that has a post that fits into the pocket screw hole. Does a good job, especially if you make sure all your cuts are exactly 90 degrees (Wixey digital angle gauge).
Name:	Pocket Screw Right Angle Clamp.jpg
post #15 of 15 (permalink) Old 09-11-2019, 03:37 PM
I good finish carpenter always used to have at least one of those in his gear, with the 1/2" plywood like Stick commented on. Also had the same thing a foot wide with 2 casters on it to move those big heavy solid core doors around.
Herb Stoops is offline
