Kliss Clamp - Router Forums
 15Likes
post #1 of 15 (permalink) Old 09-10-2019, 08:28 AM Thread Starter
sreilly's Avatar
First Name: Steve
Default Kliss Clamp
Got an email from a dealer I often use and found this to be an interesting clamp to think about. It's called the Kliss Clamp made by a cabinet maker for use in his production shop. Looks like an ideal clamp to have and appears very useful especially if clamped down or secured in some other way to your work surface. I haven't seen anything like this before and the wedge seems like a great idea. You can see it here And no, I'm not linked to this in any way, just passing along what I think is a great idea.
Wildwood and Herb Stoops like this.
sreilly is offline
post #2 of 15 (permalink) Old 09-10-2019, 09:43 AM
link??? picture???
Stick486 is offline
post #3 of 15 (permalink) Old 09-10-2019, 09:46 AM Thread Starter
sreilly's Avatar
First Name: Steve
It's like Ragu, it's in there. It's linked to the "here" but again try this https://www.hartvilletool.com/product/62164/clamps
sreilly is offline
post #4 of 15 (permalink) Old 09-10-2019, 10:02 AM
ahhhh!!!
thanks...
Stick486 is offline
post #5 of 15 (permalink) Old 09-10-2019, 10:04 AM
This is what I use. Smaller, and in my opinion a bit more versatile.
Name:	clamp aids 001.jpg
roxanne562001 and Nickp like this.
post #6 of 15 (permalink) Old 09-10-2019, 10:21 AM
That would be handy for case work. Don't do much of that amymore, and have always used other methods to hold things vertical. Wondered why it has a cutaway base and then realized that allows you to lay the edge flat to join to another piece.
I noticed in the video that it didn't lock the workpiece vertical. There was some play that allowed the piece to rock back and forth. I think you could make something like this fairly easily, perhaps with a little more bracing. Nice item though.
post #7 of 15 (permalink) Old 09-10-2019, 12:51 PM
kp91's Avatar
First Name: Doug
I love how everything 'old' is new again, I have a horizontal clamp very similar to this application that has been handy for working with small parts over the years. I don't know how old it is, but the phone number has 'words' in it... so it's back a ways. It came to me from my Great-Uncle out in Shelbyville, IL about 25 years ago. I screw it down to the bench wherever and whenever needed, otherwise it lives in it's box.
The clamp is surprisingly strong for it's size.
Those kliss clamps would come in handy if working on a lot of doors, or other big bits that need to be worked on edge. If you are a contractor finishing a house, I be they are very handy and portable.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #8 of 15 (permalink) Old 09-10-2019, 02:42 PM
JOAT's Avatar
First Name: Theo
Certainly wouldn't buy one if I wanted one. Should be plenty easy to duplicate, for very few $.
JOAT is online now
post #9 of 15 (permalink) Old 09-10-2019, 06:23 PM
Lots of ways to do that, and without spending any money. I believe that Mike @MT Stringer showed a version of #3 in a post a while back. You can also use this method to hold a door for trimming, cutting hinge mortises, etc., just clamp to a sawhorse with the jaws overhanging, separate the sawhorses by the appropriate distance and clamp the door in place - finally, a use for those 12" hand screws that you bought on a whim
Name:	Trimming  fixture.jpg
jw2170 and MT Stringer like this.
Last edited by tomp913; 09-10-2019 at 06:24 PM. Reason: forum moved my attachments around, refers to the sketch with hand screws on bench top
tomp913 is offline
post #10 of 15 (permalink) Old 09-11-2019, 07:15 AM Thread Starter
sreilly's Avatar
First Name: Steve
Tried calling and no answer......probably out of stock and shipping maybe an additional $0.25. I'll bet gas was a lot cheaper then as well.........
kp91 and TenGees like this.
sreilly is offline
