Which nailer? - Router Forums
 16Likes
post #1 of 34 (permalink) Old 09-19-2019, 07:30 PM Thread Starter
First Name: Wayne
Default Which nailer?
Hello folks,
I am about to invest in a nailer or two. My projects are small using 1/4 to 3/4 inch plywood (current project: dollhouse). I have been looking at an 18 ga. brad nailer and a pinner. I am not sure which would work best for the 1/4" walls and roof. I am leaning toward a couple of Bostitch nailers and a Craftsman 6 gal pancake compressor (Lowes). Your guidance will be greatly appreciated.
Sawdust68 is offline
post #2 of 34 (permalink) Old 09-19-2019, 08:06 PM
David Bradford's Avatar
First Name: David
For your 1/4" parts a 23 ga pin nailer. I have Bostich guns and pancake compressor myself.
David Bradford is offline
post #3 of 34 (permalink) Old 09-19-2019, 08:12 PM
graeme.c.payne's Avatar
First Name: Graeme
If there's a Harbor Freight near you, take a look at their tools. I have one of their framing nailers (for a couple of years) and a small brad nailer for about 3 months. They get air from a Lowe's (6 to 8 gallon?) compressor. They both work just fine for me as a part-time casual woodworker.
If you are putting nails in wood as a construction professional, they may not hold up as long as the $$$$ brands. But for my uses they are fine.
Why the framing nailer? I needed one for a specific task, building a wall to make an office in part of the workshop. Looking at options, it was cheaper to buy one from HF than rent one for a week from a big-box store. Since then it has only had a few days of use, and I will probably drop it off at the Habitat for Humanity store by the end of the year.
mgmine likes this.
Graeme C. Payne
Middletown, Maryland, USA
I try to learn something new every day. Then I try to remember what it was!
graeme.c.payne is offline
post #4 of 34 (permalink) Old 09-19-2019, 08:32 PM
The Bostich guns are nice because they don't need to be oiled. However, ergonomically my PC 18 gauge is more comfortable than my Bostich brad nailers. I have an Hitachi framing nailer and it has a lot of power. It seems more powerful than the Holzher it replaced. I also have an Hitachi pin nailer. It works well but it has a safety on the trigger and I wound up taping it down so I didn't have to use it. That's never been an issue in the two years I've had it but if someone else has a brand that works well I'd go with theirs. The Bostich narrow crown stapler uses 6mm staples instead of 1/4" and the Bostich brand staples are way more money here so you may want to check that out. I also have a Campbell Hausfeld in 1/4" and it has worked fine and staples are cheap. Medium crown I've only ever used a Bostich so I have nothing else to compare it to.
post #5 of 34 (permalink) Old 09-19-2019, 08:39 PM
First Name: JJ
I have PC nailers , but I have to say I enjoy using my Ryobi cordless nailers more lately. Have both the 18ga and the 23ga pinner. No worries about hoses or the noise of a compressor. Just my 2 cents
billyjim likes this.
Flipsaw is offline
post #6 of 34 (permalink) Old 09-19-2019, 09:20 PM
kp91's Avatar
First Name: Doug
For 1/4 inch ply I usually use staples if I can (for cabinet backs, etc). For a doll house the brads should be fine as a backup to the glue.
I have a California Air Systems quiet compressor, definitely worth the extra $60 over your average compressor. I honestly forget to turn the thing off sometimes it is so quiet. I got mine on a black Friday deal, and signed up for their credit card to get an extra $50 off, fantastic buy. Lowes and HF have their own knock offs of the CAL compressor now, you might be able to score something very similar for less.
I have a Accuset 23 ga pin nailer, and love it to death.
I use the super cheap HF 18 ga pin nailer and the 18 ga nailer/stapler combo. For the $ they can't be beat. Just fire a few test brads into similar wood and adjust the regulator on the compressor.
I CAN'T STAND my HF 16 gage nailer, I only use it if I absolutely have to
I have a Hitachi 15 gage nailer that I use for everything the 18 ga brad nailer can't do. It is an awesome piece of equipment.
https://www.amazon.com/California-Ai...s%2C146&sr=8-5
sreilly likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #7 of 34 (permalink) Old 09-19-2019, 09:37 PM
I have and like my Hitachi 18 gauge nailer. Often use it on projects to hold things in place until I can get a few screws in place. For this purpose I often use the 2.5 inch nails, the maximum size. It also uses easy to get Porter Cable nails.
I have an off-brand 23 gauge pin nailer that is useful for holding things in alignment during glue up. I think with really short pins you could use it for miniatrues, but it will not hold things together. A light pull or twist will pull the pieces apart.
post #8 of 34 (permalink) Old 09-19-2019, 11:25 PM
JOAT's Avatar
First Name: Theo
My nailer of choice for a doll house build.
Name:	a tackhammer.jpg
kp91 likes this.
JOAT is online now
post #9 of 34 (permalink) Old 09-20-2019, 07:25 AM
roxanne562001's Avatar
First Name: Roxanne
I have a harbor freight pin nailer that works great for thin material. I also have their 18 ga brad nailer /stapler that works well also. The pin nails don't split the thin stock. I use that on toys I make. I use both of them weekly for the past several years with good result. I can't advise you on the compressor. I have a large stationary air compressor unit. You can never have to much air
roxanne562001 is online now
post #10 of 34 (permalink) Old 09-20-2019, 07:31 AM
Bushwhacker's Avatar
First Name: David
Originally Posted by Sawdust68 View Post
Hello folks,
I believe Home Depot had a combination pan cake and two nailers for 100.
Haven't been back to see lately but they may still be there.
David
When the enemy is in range, so are you.
Bushwhacker is offline
