Advice on Hot Glue Guns - Router Forums
 19Likes
post #1 of 31 (permalink) Old 09-24-2019, 09:12 AM Thread Starter
sreilly's Avatar
First Name: Steve
Default Advice on Hot Glue Guns
After having looked online I have to say I'm more confused then ever when it comes to what works well and not. I often will look at an item and give the reviews a good look over to see if there is any consistency in their findings. More times than not you can attribute the bad reviews to either lack of how to use something or just plain junk. Now so far it appears glue guns are relatively cheap but I detest buying junk and having to replace something often so I try to be smart about these purchases. I'd rather pay a bit more and get quality then buy cheap and often which turns out to be more expensive and time consuming. I also don't want to beta test a product.
This all came up when I needed a hot glue gun to use while working on a planer sled to secure the shims. I went to my tool chest where I knew I had my father-in-law's old Craftsman hot glue gun and glue sticks. They've been there for years. Glue gun, glue sticks......where's the power cable? No where to be found is the power cable..........Can't say whether this gun works or not so I go looking anywhere i might have a cable that works but nothing close and Sears doesn't have nay information on this anywhere. So I make a quick cable to test and make sure it even works which it does but now need to find a proper cable or buy a new hot glue gun.
I'm a very experienced Amazon buyer but can tell you their reviews are a mess. Say you're looking at a abc123 model Netgear router , I know this is a woodworking forum...., the reviews you'll find seem to cover every Netgear model out there, not necessarily the one you are looking at so the reviews are a mess and not very useful. Hot glue guns seem to be about the same so fairly worthless.
I have two choices, search for a proper cable and use what I have (preferable) not because I'm cheap but rather because I would rather use what I already have then throw away something that works away or buy a new hot glue gun. Of course there's the sentimental value of it being my FIL's old glue gun to consider as well.
So anyone have a good source for 110V power cables? If not, have any suggestions on a good hot glue gun that should last and works properly. I see lots of reviews that say things like "glue runs out when it's not needed", "broke after 2 uses", "doesn't work at all".....and I have no desire to go through that process. I mean it's a hot glue gun, how difficult is it to get one that works and lasts?
sreilly is offline
post #2 of 31 (permalink) Old 09-24-2019, 09:56 AM
Honored Member
harrysin's Avatar
First Name: Harry
This low cost glue gun is well over 25 years old and has never missed a beat. Probably because they aren't used as often as most other tools they have a long life and can be bought on Ebay for from $4.00 to about $35.00 dollars. Go middle of the price range and you will probably one day leave it to your son!
Name:	glue gun0001.jpg
TenGees, jj777746 and sreilly like this.
Harry
harrysin is offline
post #3 of 31 (permalink) Old 09-24-2019, 10:49 AM
Gene Howe's Avatar
First Name: Gene
I have a couple. One really cheap and, one I just bought for around $26 USD. The new one heats faster and hotter @100 watts. It's a Chandler "Heavy Duty Commercial" model. Found it on Amazon. I really like it.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 31 (permalink) Old 09-24-2019, 11:54 AM
Gaffboat's Avatar
First Name: Oliver
I'm happy with this glue gun from Amazon. I like the longer nozzle and dual heat temperatures. Plus it doesn't drip like the others, and actually stands up on its own when you're waiting for it to heat or while setting up for the next glue operation. It also heats up quickly. It seems like other glue guns take forever to get to the point where the glue actually begins to melt. For under $25 I think it's a steal.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Gaffboat is offline
post #5 of 31 (permalink) Old 09-24-2019, 12:09 PM
Here is one you might get to work:
https://laptopparts.com.au/ac-adapto...d-2-prong.html
I see where most guys are just rewiring a cord direct to their glue guns. If you do be sure to use a clothes iron or waffle iron or portable heater cord that are designed for high heat appliances.
hope this helps,
Herb Stoops is online now
post #6 of 31 (permalink) Old 09-24-2019, 12:18 PM
David Bradford's Avatar
First Name: David
This one is a little more pricey but it is the best one I have used and we have had it for more than 20 years.
https://www.amazon.com/3M-Applicator...7&sr=8-55&th=1
David drafter @ Linear Fine Woodworking in Phoenix
[email protected]
http://www.linearfinewoodworking.com
David Bradford is offline
post #7 of 31 (permalink) Old 09-24-2019, 01:05 PM Thread Starter
sreilly's Avatar
First Name: Steve
Thanks for the assist guys......I think I have this covered now. Will try the wire cord 1st and then if that fails go for the new gun.
sreilly is offline
post #8 of 31 (permalink) Old 09-24-2019, 04:39 PM
Country: South Africa
First Name: Biagio
@sreilly ,
The type of cord suggested by Herb must be commonly available in the U S. My Apple computer uses one, so do various (telecomms) routers and modems.
Biagio is offline
post #9 of 31 (permalink) Old 09-24-2019, 05:21 PM
Why would a laptop have a heat resistant power cord? That's what Herb is referring to; some cords are rated specifically ((sheath and insulation) for use with heat generating appliances (just in case there was a misunderstanding).
https://www.amazon.ca/PRIME-HC100608...SIN=B0022NH72W
Yeh, I know, wrong female connector.
DaninVan is offline
post #10 of 31 (permalink) Old 09-24-2019, 07:18 PM
Not sure that the one I showed is heat resistant, not sure the female would even fit. After I posted that I got to thinking, that sure looks like a computer/printer lead. I think the female end is too large.
My wife had the same one Steve is showing, for her craft work, and if I recall it just had a regular 16 ga. cord. I think that a person could direct wire a 16 ga. or larger cord on the gun without too much problem.
HErb
