Please help me find this "joiner" - Router Forums
 24Likes
post #1 of 15 (permalink) Old 09-26-2019, 09:17 AM Thread Starter
Default Please help me find this "joiner"
I'm making a cribbage board. It will have two layers, each 3/4" thick. Top one is the board itself. Bottom layer is for card and peg storage. I would like to "join" these two boards in one corner with a rivet type of joiner. What I picture is a 1.5" t shaped top with a mating t shaped bottom,with one barrel slightly larger than the other. Drill an appropriate hole; slip one barrel into the hole. Slip second barrel into the first barrel. Press or hammer them together. Presto -- a nice looking, permanent and functional swivel joiner for the two boards with dime sized discs showing on top and bottom.
But how it works is secondary. Main thing is to have a nice looking, permanent and functional swivel joiner for the two boards. I don't think screw type (t nuts) of joinery would work because it would be prone to coming loose and falling apart.
I'm pretty sure what I'm looking for is out there. I just don't know what to call it or where to look.
meyster is offline
post #2 of 15 (permalink) Old 09-26-2019, 09:31 AM
sex bolt...
harrysin and tomp913 like this.
Stick486 is offline
post #3 of 15 (permalink) Old 09-26-2019, 09:35 AM
roxanne562001's Avatar
First Name: Roxanne
What if you used something like this cut the bolt so it just bottoms in the head before is to tight and use loctite on the threads. https://www.amazon.com/binifiMux-10-...=ATVPDKIKX0DER
harrysin, DaninVan and tomp913 like this.
roxanne562001 is offline
post #4 of 15 (permalink) Old 09-26-2019, 11:08 AM
Compression rivets if you can find them long enough. They're what's used to attach the scales to a knife handle. https://www.amazon.com/compression-r...ression+rivets
Sex bolts are also known as Chicago screws.
harrysin and roxanne562001 like this.
post #5 of 15 (permalink) Old 09-26-2019, 11:36 AM
"Sex bolts are also known as Chicago screws."
*shock!*
They're a common office supply store item.
DaninVan is offline
post #6 of 15 (permalink) Old 09-26-2019, 01:45 PM
those are generally called binding posts...
DaninVan likes this.
Stick486 is offline
post #7 of 15 (permalink) Old 09-26-2019, 02:23 PM
Prertty sure if i went into my local office supply store and asked for 'sex bolts' I'd be ushered out...
DaninVan is offline
post #8 of 15 (permalink) Old 09-26-2019, 05:53 PM
David Bradford's Avatar
First Name: David
They are called sex bolts or connecting screws at cabinet hardware suppliers like Louis and Co.
harrysin likes this.
David drafter @ Linear Fine Woodworking in Phoenix
[email protected]
http://www.linearfinewoodworking.com
David Bradford is offline
post #9 of 15 (permalink) Old 09-26-2019, 08:30 PM
I doubt it...
try it and get back to us..
sreilly likes this.
Stick486 is offline
post #10 of 15 (permalink) Old 09-27-2019, 12:28 AM
You try it; i have a reputation to maintain...
harrysin and sreilly like this.
DaninVan is offline
