New project - Router Forums
 15Likes
post #1 of 12 (permalink) Old 10-05-2019, 07:50 PM Thread Starter
roofner's Avatar
First Name: Gary
Default New project
I am in need of more tool storage . I am working on building two roll around tool carts. I am going use the carts to build a modular units to serve as just individual carts, roll around workbench , cutting large panels with track saw and kreg jig pocket hole jig table. Build pictures to come next week.
roofner is offline
post #2 of 12 (permalink) Old 10-05-2019, 11:25 PM
Old_Tom's Avatar
Sounds good Gary. Multi-functional as well....great idea! Looking forward to seeing the pics.
There's nothing like the smell of raw wood in the morning!!
Old_Tom is offline
post #3 of 12 (permalink) Old 10-06-2019, 12:28 AM
All carts made to identical dimensions, and some sort of clamps to hold them together in alignment when you use it as a bench. Sawdust gets into any open constructions, shelving open drawers or doors, so I'd make sure drawers and doors enclose everything. Use plastic windows in the doors so you can see what's inside. 24x36 inches top would give you a 2x6 ft work surface. Later, when you build a serious workbench, you repurpose the stands for a drill press, small band saw, sander, small jointer or planer. I have a couple of steel stands I've enclosed that are similar in form and very handy. One is open (router table) the other is enclosed for storage of 18v tools. It needs a few drawers, but never got around to it.
I have two areas with wall shelfing. One is wire shelving and is fairly deep, and it holds identical size plastic tubs with lids and labels on each stating what's inside. On the other side are open shelves. Keep open shelves shallow (7 and 10 inches deep) so I can't stack things in front of unrelated items. Just my take.
jj777746 likes this.
post #4 of 12 (permalink) Old 10-06-2019, 08:24 AM Thread Starter
roofner's Avatar
First Name: Gary
Tom I was wondering about that being a problem. Thanks for that info. One will have 3 drawers. The other will have 3 shelves with a door and large opening in the bottom for my track saws.
DesertRatTom likes this.
roofner is offline
post #5 of 12 (permalink) Old 10-06-2019, 09:53 AM
sreilly's Avatar
First Name: Steve
Storage is always lacking it seems. memory isn't that great at times either so I typically make sure everything is as mobile as possible and marked well. I buy the same locking castor sets when on sale and then use the same height dimensions for these cabinets. The only deviation was the table saw cabinet and that was because it goes under the saw table extension wing.
DesertRatTom and jj777746 like this.
sreilly is offline
post #6 of 12 (permalink) Old 10-07-2019, 07:50 PM Thread Starter
roofner's Avatar
First Name: Gary
Do you think I should go with 1/2 or 3/4 plywood for bench top.
roofner is offline
post #7 of 12 (permalink) Old 10-07-2019, 07:56 PM Thread Starter
roofner's Avatar
First Name: Gary
Here are the first pictures. If you look at the first picture the top is upside down you can see the 2 by which get locked into roll around with 4 wing nuts. Second picture shows top in place. I'll have to take a closeup picture of wing nuts. One roll around will have a couple of shelves and a door on the front. The other will have 3 drawers.
roofner is offline
post #8 of 12 (permalink) Old 10-08-2019, 12:19 PM Thread Starter
roofner's Avatar
First Name: Gary
More pictures
roofner is offline
post #9 of 12 (permalink) Old 10-08-2019, 02:10 PM
3/4, definitely. And I'd use rabbets and dados to connect pieces wherever possle rather than pocket screws alone. The two make a forever joint and pocket screws have a way of aligning pieces as you tighten them up.
If you want the tops to be very flat and stay that way, put a second layer of MDF underneath the top. My workbench has a changeable layer of masonite on top. Quick replacement when the time comes.
For quick doors, I have used 1/2 ply, and made a sort of face frame on top of that to make it look good. The ply is very stable and if you do a double door, very easy to trim to an exact fit.
If you don't already have a Wixey digital angle gauge, get one and make sure you cut at a perfect 90. That will set you up for perfectly square cabinets. Even a slight angle will mess up your joints.
It's really nice to have good cabinets. Worth the effort and you learn a lot doing them.
I have one short cabinet that now holds the drill press. It started as a temperature controlled cabinet for keeping my shop laptop from freezing during winter. It is lined with 2 inches of foam with a dadiant barrier between ply and foam. I found a greenhouse temperature controlled swith, and put a 40 watt bulb in so if the temperature hit a low setting, the light came on and warmed up the cabinet. Don't use it for that anymore, so the low height turned out perfect for the drill press.
post #10 of 12 (permalink) Old 10-10-2019, 06:55 PM Thread Starter
roofner's Avatar
First Name: Gary
Default Here are pictures of carts on wheels.
I am making progress first modular top almost finished. It has a kreg jig mounted with dust collection connected. Top should be interchangeable between carts. But this cart will have drawers under it mostly my drills ,bits ,wrenches , and allen wrenches . Also squares , measuring tools and Kreg accessories . Other cart will be for track accessories and using both carts connected together to form a 6 ft. cutting bench. Planed to have a separate connected workbench for assembly . Here are the new pictures. You will see I took Tom's idea to add hardboard to the top.
roofner is offline
