First is multi use, but mostly used to check slot-blade alignment, but mostly for setting the fence. $100, but such a pleasure to use once in awhile. No regrets.
Second, the coping sled I don't use...unnecessary item. Wasted money.
The third is the plate for my Triton router, extra thick, twist lock inserts and many sizes of snap-in inserts. Really like it, overpriced, but worth it. Probably won't sag for a million years.
Other than that, I haven't seen a one time tool worth the high cost, but they are pretty to look at.
In Woodpeckers case the cost greatly exceeds the neat factor in pretty much every case. I don’t mind paying extra for quality but they’re past that point of diminishing returns.
I don't do this type of trenching as an exact fit. I set the top of the trench line exactly where I want it and run the trench with a router, I use any cutter that is at least 3/4ers the stock thickness, then I do a rebate on the underside of the stock and that rebate serves a few purposes, One, it leaves the tenon the correct thickness for the groove and two, it leaves a shoulder that sets and exact width when the stock is inserted. This type of groove and rebate joining, can be used for any construction, so I do that and three, it also deals with any stock that varies in thickness quite well, I don't do exact width grooving. N
Related Threads
747K posts
128.1K members
Since 2004
