Bandsaw radius guide - Router Forums
 12Likes
  • 9 Post By DesertRatTom
  • 3 Post By Cherryville Chuck
post #1 of 8 (permalink) Old 11-08-2019, 12:28 PM Thread Starter
Default Bandsaw radius guide
Found this chart showing the minimum radius you can cut with different bandsaw blade widths. You want to use the largest width blade you can for any particular cut.
Let there be light. This is my small Rikon. The light is a $2 thrift shop special with the standard half inch gooseneck end. Use an L bracket bolted to the back side of the top wheel cover. Drill a half inch hole and mount gooseneck. Run the power cord across the back, down to the saw's spine, out of the way. I use a small, medium base, 50 watt equivalent LED spotlinght bulb that doesn't heat up. Simple, cheap doesn't do damage to the saw's structure.
Here's a link to a circle cutting jig for a band saw. Mine is even simpler and just clamps to the router table. Cut a slot for the blade slightly longer than half the table. Drill holes every inch for a peg. Make gross size adjustments with the pin, fine adjustments to radius by moving the jig a bit. Mark where the blade goes to cut to the inch. Attach a stop piece to the front edge of the base first, then mark the blade location on side, then cut the slot. You can make it in 15 minutes or so.
Just sharing some stuff I found this a.m. BTW, the Rikon and WEN 10 inch saws are identical structurally, but the WEN is about $90 less.
Name:	Bandsaw blade-radius.jpg
Name:	light on Rikon 12.jpg
post #2 of 8 (permalink) Old 11-08-2019, 12:46 PM
Good stuff Tom. My circle cutter was slightly different in that it had a strip under to run in the saw's miter slot so that you could advance the piece's edge into the blade which makes starting the cut easier and straighter. The pivot pins have to line up at 90* to the front of the blade when the stop hits the edge of the table.
TenGees, Nickp and dirt_dobber like this.
post #3 of 8 (permalink) Old 11-08-2019, 01:08 PM
Nickp's Avatar
First Name: Nick
Very nice...mine is similar...very handy and much cleaner than most other methods...
Nick
Nickp is online now
post #4 of 8 (permalink) Old 11-09-2019, 07:27 AM
sreilly's Avatar
First Name: Steve
Haven't had to cut any circles yet Tom but good to know. If there was a link intended I don't see it.
sreilly is offline
post #5 of 8 (permalink) Old 11-09-2019, 01:24 PM Thread Starter
No link, just print the table. It's a jpg.
post #6 of 8 (permalink) Old 11-11-2019, 02:04 PM
First Name: Steve
Thanks for posting the chart, Tom.
ScottyDBQ is offline
post #7 of 8 (permalink) Old 11-11-2019, 06:20 PM
TenGees's Avatar
First Name: Paul
I haven't tried any re-sawing so a 3/8" looks like a good compromise to me.
TenGees is offline
post #8 of 8 (permalink) Old 11-11-2019, 07:47 PM
OutoftheWoodwork's Avatar
First Name: Barb
Awesome! Thanks, Tom
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
