Mibro dado Blades - Router Forums
 1Likes
  • 1 Post By anndel
post #1 of 6 (permalink) Old 11-16-2019, 06:38 PM Thread Starter
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Default Mibro dado Blades
Any one familiar with this dado set?
Opinions?
Does it cut a TRUE flat dado?
Is it worth the $$---somewhat?
MIBRO 416381 8" Carbide Stacking Dado Blade Set - 14 Pieces
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=MIBRO+416 381+8"+Carbide+Stacking+Dado+Blade+Set+-+14+Pieces&_sacat=0
thks
smitty
smitty10101 is offline
post #2 of 6 (permalink) Old 11-16-2019, 07:25 PM
This is $44 bucks new at HD. If it's used and you can't test it, it's worth $10 or less. Top of the line is in the $300 range. I have a middle set, can't recall the brand. 8 inch, same number of chippers and shims, 8 inch, about $100. If you can get it really cheap, and it doesn't look beat up and no missing or damaged tips, it is worth trying. If everything is fine, no more than $15.
DesertRatTom is online now
post #3 of 6 (permalink) Old 11-17-2019, 01:29 AM
Mibro is at the lower end of the quality spectrum. I can't say whether it will cut flat or not.
post #4 of 6 (permalink) Old 11-17-2019, 07:55 AM
sreilly's Avatar
First Name: Steve
If you do a search and look at reviews it seems about 20% on Amazon call it junk because of the less than flat bottom cut. I guess it really depends on what quality you want/need and how much clean up you're willing to do. I have a Freud set that does OK but not the greatest either. That said I think it was a $90 set. A really good set could cost you up to several hundred more. But I'm particular about buying "stuff" that doesn't have a good return policy to. If it doesn't do the advertised job it's going back. Plain and simple. Check reviews and make sure it's for the product you're interested in as Amazon has a bad habit of grouping "all" let's say blades as blades and not their respective brand/model. Just saying, read reviews from multiple sources and see what they say.
sreilly is offline
post #5 of 6 (permalink) Old 11-17-2019, 12:58 PM
Mine's a DIMAR 8" set and it's been excellent! Comes with a really nice foam packed storage case. Not cheap, but I'll have it for the rest of my life.
I have one niggly little complaint ("Of course you do, Dan; we'd expect nothing less!")
The plastic shims have a precisely punched arbor hole that is pretty much exactly the size of the arbor. Putting them on and off is a royal p.i.t.a!
No idea why they didn't allow some wiggle room on the hole size; can't see how a few thou of slop would matter for a shim...there's virtually no mass involved.
I'm seriously considering looking for 3rd party shims.
DaninVan is offline
post #6 of 6 (permalink) Old 11-17-2019, 01:27 PM
First Name: DC
I looked at the Mibro and passed on it as it looked cheaply made. I went with a dado stack from Ridge Carbide which was the best $250 spent.
DaninVan likes this.
anndel is offline
