12" miter saw blade - Router Forums
 27Likes
post #1 of 30 (permalink) Old 12-14-2019, 11:33 AM Thread Starter
First Name: Frank
Default 12" miter saw blade
After searching on here, I haven't found exactly the info I'm looking for. I have upgraded from my DeWalt 12" miter saw to a DeWalt 12" sliding miter saw. I want to buy another finer blade than the supplied 32 tooth. After considering both price and application, I'm kind of leaning to the Freud Diablo D12100X @ $55 on Amazon. The DeWalt blades are pricey, and their cheaper ones are made in China. Please, I need some guidance from the pros. Thanks. F
routafinger is offline
post #2 of 30 (permalink) Old 12-14-2019, 11:47 AM
Nickp's Avatar
First Name: Nick
Have you considered Freud's LUM82 or LUM84 (combination)...? Both are good for RAS's and SCMS's...
100 teeth seems a bit high for cross cutting...
Nick
Nickp is offline
post #3 of 30 (permalink) Old 12-14-2019, 11:49 AM
so much for the search function...
type of blade, it's purpose matter a great deal...
the blade(s) need to fit the application....
these PDF's cover this pretty well...
FWIW...
I'm very partial to Freud...
Danman1957 likes this.
post #4 of 30 (permalink) Old 12-14-2019, 12:06 PM Thread Starter
First Name: Frank
FWIW...
I do quite a bit of projects that would benefit from super smooth cuts. Mostly on smaller pieces like picture frames etc. For larger less particular cuts, the 32 tooth has been adequate. Thanks for the reading Stick. F
post #5 of 30 (permalink) Old 12-14-2019, 12:21 PM
yur welcome..
post #6 of 30 (permalink) Old 12-14-2019, 12:25 PM
I had a chance to talk to a Freud factory rep a year or so ago. I asked him what the difference is between the Diablo line (basically the DIY grade of blade) and their commercial blades in the same configurations (hook, grind, # of teeth) and his reply was nothing really except that all quality blades have thicker carbide so that they can be sharpened more times (6 as opposed to 3 I think). So before you shell out the extra money for a commercial quality blade check into local sharpening services to see how reliable they are and whether they will be cost effective. They usually charge by the tooth so a 100 tooth count may make sharpening cost prohibitive in which case it will make no sense to spend more initially.
Most SCMS blades are thin kerf because they require less torque to start which is easier on the motors. But the thin kerf affects cut quality, particularly on miter cuts where the blade literally bounces off the grain divisions where it passes from softer spring wood to harder fall wood and back. Sometimes cut quality can be greatly improved by adding a blade stiffener.
post #7 of 30 (permalink) Old 12-14-2019, 07:06 PM
Gene Howe's Avatar
First Name: Gene
Stick and I have debated saw blades endlessly. So, I'll not give my opinion of Freud.
On my Bosch Slider I've found the full thickness Tenryu Miter Pro 60 and 80 tooth to give the smoothest finish cuts. With any brand, a thin kerf blade, especially a 12", will deflect on an angle cut.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #8 of 30 (permalink) Old 12-14-2019, 10:25 PM
JFPNCM's Avatar
First Name: Jon
Just to muddy the waters a bit, would one and all recommend the same blade for a “chop” style and a “slider”? That assumes of course that the intended use is the same, i.e., a finished crosscut in hard woods.
Jon
JFPNCM is online now
post #9 of 30 (permalink) Old 12-14-2019, 10:48 PM
Fought deflection, dumped my 12 inch DeWalt miter saw over it. Just using full kerf blades on my 10 inch Bosch sliding, compound miter saw and table saw these days. Freud blades work great for me, up to 80 teeth for crosscuts, but what sits on the saw all the time is Freud's glue line blade. Wonderful blade.
DesertRatTom is online now
post #10 of 30 (permalink) Old 12-15-2019, 12:26 AM
JFPNCM's Avatar
First Name: Jon
Tom
I use the glue line in my TS and love it. I only use my Dewalt chop saw for proximal cuts, all finals are done on the TS. No room for a slider.
DesertRatTom likes this.
Jon
