Table Saw Again... - Router Forums
 17Likes
post #1 of 22 (permalink) Old 01-03-2020, 01:14 PM Thread Starter
Default Table Saw Again...
My older (113 series) Craftsman Table Saw started to slow down and even bind up on 1" boards. Figured it was time to start looking for a replacement. I really do like the saw. Grizzly, Delta, Jet, and Ridgid were what I was looking at -- $1k give or take. Then I started fiddling with the fence (Craftsman 2424). Seems it isn't lining up straight all the time. When it is right -- it cuts with no problem. So.......do I just replace the fence and which one will fit. I hear a lot about the Incra system. From what I gather - I'd have to replace the fence on anything new I bought anyway. Worth a shot before getting a new saw?
DaninVan, Herb Stoops and artman60 like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #2 of 22 (permalink) Old 01-03-2020, 01:29 PM
Repower it..
as for the fence.. I'm partial to Vega..
https://woodsmithspirit.com/best-table-saw-fence/
https://sawingpros.com/best-table-saw-fence-reviews/
https://reviewinfinite.com/best-table-saw-fence/
roxanne562001 and Herb Stoops like this.
post #3 of 22 (permalink) Old 01-03-2020, 01:54 PM
RainMan 2.0's Avatar
I had a Biesemeyer fence on my Delta contractor saw and it made the saw
radios, Herb Stoops and artman60 like this.
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 22 (permalink) Old 01-03-2020, 03:01 PM
Nickp's Avatar
First Name: Nick
If you can buy the fence and still be able to use it on a future replacement saw, it would be worth a shot. But you might want to consider that Stick's suggestion to repower might be necessary anyway. So if you like the body/bones and other parts are good (arbor, bearings, etc) go with the fence and motor...
Having said that, there are some really good saws out there if you just want to take your shoes off and jump with both feet...
My Darra James and Bosch 4100 are sporting their stock fences so can't help with a recommendation...
roxanne562001 likes this.
Nick
Nickp is online now
post #5 of 22 (permalink) Old 01-03-2020, 03:34 PM
PhilBa's Avatar
First Name: phil
I got fed up with my Craftsman TS a long time ago. It was a similar to yours, I believe. Ultimately, I wanted more power and went for a Griz 1023 3HP. very happy I did. The fence on it is quite good.
Looking at refurbishing is always a good idea. A couple of things to consider, though. Foremost is what motor does it have. I wouldn't put in a more powerful motor so that kind of limits you. Also, what kind of belt does it have. My CMan had just a single belt. Prone to slipping. There are some good aftermarket upgrades for that. A new fence makes a lot of sense. I considered getting an Incra because the one on my router table is awesome. However, it takes a LOT of extra space which I ultimately decided I didn't want to take up with a fence. Also, my CMan had a weird splitter while my new griz has a riving knife. I would get lots of binding with the CMan, none with the griz with the riving knife installed. I would definitely look to add one if you don't already have. A few other mundane things can improve your TS - clean and sharpen the blade, narrow kerf blade (takes less power), clean and wax the table top.
Unless you can't afford it, I would say get a more powerful saw. It really makes a difference. The one I got costs 1500 now (Griz 1023). Maybe a used 3HP would work.
Knot working likes this.
Visit my shop website.
PhilBa is offline
post #6 of 22 (permalink) Old 01-03-2020, 05:42 PM
Sometimes the slowing down is a bad bearing which may not be that expensive to fix. Fences can make a world of difference. I have one of these on my backup saw from Mule/Accusquare and it's first rate and less than most others. Mule Cabinetmaker - Carpentry Tools for Carpenters that Need Precision & Reliability!
The extra hp like suggested is good and the big saws will come with a pretty good fence system. If you have the cash and the room you won't regret going big but remember that once you plop one of the 3 hp beasts down it's there for a long time. They don't move easily or well.
post #7 of 22 (permalink) Old 01-03-2020, 06:53 PM Thread Starter
It seems to have the power when the fence is straight. Just slows down when it's cutting on that slight angle. I'm thinking the Vega fence that Stick likes (supposed to fit this saw) and a chain link belt and maybe new pulleys. The fence can always be put on another saw.
HJ
Detroit Burbs
post #8 of 22 (permalink) Old 01-03-2020, 07:53 PM
how much HP do you have now???
are your blades sharp.. and not - you guess they're sharp... or they should be sharp..
why the pulley???
and those chain link type belts only mask the symptoms - they don't fix the problem...
artman60 likes this.
post #9 of 22 (permalink) Old 01-03-2020, 08:21 PM Thread Starter
It's the original motor. Been doing a good job since I've had it as far as power.
I'm using a Ridge Carbide blade. It is sharp.
Turned out to be the pulley the time I had problems. Replaced the arbor pulley with an ACE hardware one cause that's all I could get at the time. Seemed to work ok then.
HJ
Detroit Burbs
post #10 of 22 (permalink) Old 01-03-2020, 09:19 PM
MT Stringer's Avatar
I had my dad's Craftsman TS and upgraded it to a Vega fence. The fence was much bigger (my fault for ordering the wrong one). Then I bought the Grizzly 1023 3hp. Love it!
MT Stringer is offline
