Need help with drill press cabinet buid - Router Forums
 34Likes
post #1 of 15 (permalink) Old 01-04-2020, 09:21 AM Thread Starter
roofner's Avatar
First Name: Gary
Default Need help with drill press cabinet buid
Should I use 3/8 bolts to fasten the drill press? Is 2 enough or should there be 4? Should I put 2 or 3 brace in the back to keep from racking?
Should I use carriage bolts?
roofner is offline
post #2 of 15 (permalink) Old 01-04-2020, 09:23 AM
full back and 4 bolts..
Stick486 is offline
post #3 of 15 (permalink) Old 01-04-2020, 09:27 AM
roxanne562001's Avatar
First Name: Roxanne
I am with Stick plywood full back and 4 3/8" carriage bolts.
roxanne562001 is offline
post #4 of 15 (permalink) Old 01-04-2020, 09:40 AM Thread Starter
roofner's Avatar
First Name: Gary
A back is a given braces are for racking. Were on the same page. Thanks all I know I could count on you.
roofner is offline
post #5 of 15 (permalink) Old 01-04-2020, 12:59 PM
Forum Moderator
MT Stringer's Avatar
Gary, it took me a while to find my thread, but here is the link to the cabinet I built for my drill press. It has worked great. Hope you find some inspiration.
https://www.routerforums.com/show-n-...s-cabinet.html
MT Stringer is offline
post #6 of 15 (permalink) Old 01-04-2020, 01:21 PM
RainMan 2.0's Avatar
Originally Posted by MT Stringer View Post
Gary, it took me a while to find my thread, but here is the link to the cabinet I built for m drill press. It has worked great. Hope you find some inspiration.
Wow Mike that’s one hell of a job . Very interesting base also. Had to bookmark this for a future project
MT Stringer likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #7 of 15 (permalink) Old 01-04-2020, 03:59 PM
Knothead47's Avatar
Four bolts- little bit good, whole lot better as my grandfather would say. I made my DP/BS table out of 2x4s and a laminate sink cut out. Let's see some photos of the finished cabinet.
John T.
Knothead47 is offline
post #8 of 15 (permalink) Old 01-04-2020, 04:15 PM
Gary; this has come up in the past; the DP on top of a narrow cabinet is inherently unstable, especially if it's on castors. You need a fairly wide footprint to avoid the possibility of the DP falling over. A lot of weight low down in the cabinet helps as well. Being bolted to the cabinet gives a false sense of security, if it has a narrow base.
DaninVan is offline
post #9 of 15 (permalink) Old 01-04-2020, 10:47 PM
Forum Moderator
I can attest to my set up. I drilled all of my cabinet door hinge pockets without issue. That included some tall doors. I think the HF castors, which are outboard of the cabinet, helped steady the entire cabinet/drill press.
Name:	2013-08-16 17.38.09.jpg
Name:	2013-08-16 17.41.44.jpg
Name:	2014-07-03 11.21.57.jpg
Name:	2014-07-03 11.22.16.jpg
post #10 of 15 (permalink) Old 01-05-2020, 12:33 PM
Re Mike's experience; There must be a recognized formula for establishing a safe base width? I think ( without going and checking*) mine is 2X the DP table width(?), with the castors at the outer edges.
* It's poring rain so nope, nope, nope...
DaninVan is offline
